    [Plugin] JS Random Move
    8 Posts 2 Posters 3.9k Views 2 Watching
    • PixeroP
      Pixero
      A plugin that can move selected entities randomly within range in one, two or three axis.
      https://sketchucation.com/pluginstore?pln=JS_Random_Move
      You can also take a look at my plugin Chaos that moves, scales and rotates randomly.
      http://sketchucation.com/forums/viewtopic.php?f=323&t=71774
      • R
        rv1974
        Does it work with global ** local axis?
        • PixeroP
          Pixero
          Global...for now.
          • R
            rv1974
            There's over 9000 free randomizators (move\scale\rotate) avaible for 3ds Max (working with local\global axes). I'm pretty shoked after almost 20 yers there's none in SU πŸ˜•
            Missing it so much
            • PixeroP
              Pixero
              @rv1974 said:
              I'm pretty shoked after almost 20 yers there's none in SU.
              There is now. πŸ˜„
              Updated to 1.1 with World axis, Current axis and Local axis movement.
              A tip if you want to move a defined distance and NOT random is to set the low and high values to the same. Also note that the values can be negative so for example it can be Low: -100 and High: 100.
              • R
                rv1974
                Hi Pixero and thanks for sharing! Could the script memorize last used inputs ('Use' and 'Axis' parts? Wouldn't it be cool if it was non-modal?
                P.S. in addition, please check PM.
                • PixeroP
                  Pixero
                  I'll look into it.
                  • PixeroP
                    Pixero
                    v1.1.1 Small fix so that the plugin remember last used values.
