    Always face camera with View Observer - Would this work?
    5 Posts 4 Posters 10.7k Views 4 Watching
    • PixeroP
      Pixero
      I was thinking of a way to create a custom "always face camera" script and this is the idea.
      Would this work or am I missing something about how a ViewObserver works?
      If it did work, would it be terribly slow?
      Idea:
      Run script to set "Face camera" attribute for the selected component(s).
      Use a ViewObserver that is called when the camera is moved.
      Get the active camera position.
      The ViewObserver "tells" components with the "Face camera" attribute to rotate towards the new camera position.
      • fredo6F
        fredo6
        Are you willing to simulate in Ruby the 'Always Face camera' of Sketchup. Then what effect do you wish to get exactly?
        • PixeroP
          Pixero
          If it was possible I thought it would be good to have that functionality in a form that might work better with third party render engines and also the possibility to enhance it with some new functionality.
          • pbacotP
            There's an issue in Twilight Render where you can designate the scene to render, but if SketchUp is not set to that scene, face-me is not right. (I think that's how it works).
            • Dan RathbunD
              Dan Rathbun
              A major drawback is that you'd be modifying the model entities with every change of the camera.
              Currently changing the camera position or even the active scene does not set the modified? flag.
              I'm not here much anymore.
