    Default arc and circle setting
    1 Posts 1 Posters 2.1k Views 1 Watching
    • D
      dtrarch
      Hi all
      Good news
      There is a TIG plugin that will set arc and circle defaults (kind of)for up to SU 2018 πŸ‘
      Tig-CircleArcDefaulter_v5.0.rbz
      To make the changes from SU preset just change the segments in the Edit Defaults plugin menu.
      Not such good news. πŸ‘Ž
      You must re-start Sketchup to make the changes stick. πŸ‘Ž
      At least one can now have the proper resolution for renders and such to start with. πŸ‘ πŸ‘
      Sure would be super if TIG or someone could update this one to avoid the SU re-start to set the defaults.
      Cheers
      dtr
      TIG-CircleArcDefaulter_v5.0(2).rbz
