    Great plugin request
    8 Posts 5 Posters 4.2k Views 5 Watching
      turbodizayn
      Hi everybody! I have idea for a UNIVERSAL improvement for SU.It is quite possible, to replace some organic modeler tools by standart SU tools if apply it to SOFT SELECTED edges (ends of edges in deed) and faces. Just imagine- select one edge > moove it and it affected bezie editing type!!! and it should work with surfase boundin edges too. I tried vertex tool for example, and this SOFT SELECT TOOL could be more comfortable. It cold use reference points, axes, planes of SU, native SU tools.
      May be this tool should work in the selected object range. You have to select several connected edges, then start to drag one of them (central for example) and get effect on selected edges only. But with soft mode!
      It is impossibe with TT_vertex tool. Selection along selected edge only!
        turbodizayn
        It is realized in Rhino 3d
        http://docs.mcneel.com/rhino/6/help/en-us/index.htm#commands/softmove.htm
        • PixeroP Offline
          Pixero
          Thomthoms Vertex tools maybe?
            rv1974
            There's freight train of ideas for UNIVERSAL improvement already. Maximum you'd get is another typeline plus SU logo redesign πŸ˜„
            • pbacotP Offline
              Vertex tools has this, but development and support for TT tools seems to have ended long ago. It needs better soft select, more accuracy and more tools.
                You have also a soft selection inside Artisan! πŸ˜‰ (Rayon = Radius)
                http://moiscript.weebly.com/uploads/3/9/3/8/3938813/4019345_orig.jpg
                  turbodizayn
                  Thanks for remaining about Artisan and TT_vertex! Sandbox and native SU tools quite replace it for me do not obstruct sketchup UI, It does not give that goal to use SOFT SELECTION with native moove/rotate/scale clear and effective tools =(. And do not solve problem of bezier curve and nurbs mode editing in SU! Artisan fits for organic modeling. Soft selection + moove/rotate/scale could be more universal, simple and presize editing ability. I asked Thom_Thom to include SoftSelectionWithinPreselection ability to TT_vertex but no luck! If Vertex tool have such tool there would be reason to by it (for me).
                  T 1 Reply Last reply Reply Quote 0
                    turbodizayn @turbodizayn
                    This post is deleted!
