    Medeek Project
    125 Posts 3 Posters 19.0k Views 4 Watching
    • medeekM
      medeek
      First look at some exterior trim applied to a couple "test houses". Corner trim, band board, skirt board and frieze board.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        DXF output now enabled for Slab-on-Grade foundations.
        design.medeek.com
        • medeekM
          medeek
          Interior Bearing (ie. footing + post & beam) are now added to the House Builder.
          design.medeek.com
          • medeekM
            medeek
            First look at a basic Slab. The underlying code is very similar to a slab-on-grade so I should be able to complete this one more quickly.
            design.medeek.com
            • medeekM
              medeek
              First look at column footings:
              design.medeek.com
              • medeekM
                medeek
                First look at polyline stemwalls. Note that stemwalls and footings that are at the same Z height will auto merge for presentation purposes.
                design.medeek.com
                • medeekM
                  medeek
                  First look at a stemwall foundation with openings and a floor slab.
                  design.medeek.com
                  • medeekM
                    medeek
                    I've also enabled the entry stair option for foundation door openings
                    design.medeek.com
                    • medeekM
                      medeek
                      I'm now spending a day or two integrating the eight different foundation assemblies into the elevation views. Here is a couple examples of column footings:
                      design.medeek.com
                      • medeekM
                        medeek
                        I am now trying to wrap up stemwall foundations and the addition of windows, doors and blockouts, all within the elevation views. After further testing I'm noticing that all of this added complexity does potentially slow down the app/tool when enough windows, doors and dimensions are added. I will need to spend a few more days tightening up my "redraw" algorithms so that performance is maximized. The last thing we want is a sluggish interface.
                        design.medeek.com
                        • medeekM
                          medeek
                          I'm also adding gable walls as well as shed and hip.
                          design.medeek.com
                          • medeekM
                            medeek
                            Currently the various plan view tabs are treated as their own “sheets” or pages. In other words if you print that tab you get exactly what is in the viewport scaled to fit into a regular sheet size (letter, 11x17, Arch C, Arch D). You cannot add in other geometry from other tabs. This seems to work reasonably well for most of these plan views (ie. Floor Plan, Foundation Plan, Roof Plan, Floor Framing Plan etc…)
                            However, when it comes to elevation views things typically get a bit more interesting. Some designers like to put multiple elevation views on one sheet and in some cases all four if they will fit ( I like to do this for small ADUs for example). So it is not as easy as assigning one elevation view to one sheet, or even assigning two elevation views to one sheet, there needs to be more flexibility.
                            After giving this some considerable thought I decided what I really needed was a Layout system where the user can drag the elevations into the “workspace” and position them as they see fit, and then at that point add their annotations and dimensions. I have now created four additional Layout tabs where the user can do exactly that.
                            The only major thing I feel like I am missing at this point is a sectional view or section tool.
                            design.medeek.com
                            • medeekM
                              medeek
                              I've also add Common Truss Roofs along with Complex Roofs.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.2.8 - 10.11.2026
                                • Added the "Draw House" tool to the Medeek Builder toolbar.
                                I'm releasing this update so that interested parties can test out the House Builder interface. It is currently not fully wired into the Medeek API so have temporarily disabled the "Create House" button. I will be spending the next week or two completely the upgrades to the Medeek API for the various mdkBIM extensions so that we can access API methods for floors, foundations, roofs etc...
                                The primary purpose of this update is to garner feedback on the UI and the front end. Please download and install this latest update and send any feedback directly to nathan@medeek.com. I will be very curious what everyone thinks of this new tool and I think you will find it is much more capable than the "prototype" Garage Builder".
                                design.medeek.com
                                1 Reply Last reply 👍
                                • medeekM
                                  medeek
                                  Version 1.2.9 - 10.14.2026
                                  • Fixed a critical bug with the (Draw House) House Builder tool.
                                  • Added metric support for both the House Builder and the Garage Builder tools.
                                  If you are using the Garage Builder in metric mode you will need to update the Wall, Truss and Foundation extensions to the latest versions I have just released.
                                  If you try to use the previous versions of the plugins with the Garage Builder in metric mode it will create geometry that is corrupt and will probably cause SketchUp to bugsplat. Please uprade to the latest versions of these four plugins.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    I forgot to add in the temporary or construction dimensions. Working on that now.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      First look at some walls be generated by the House Builder. This is the easy part, next we need to add all the openings, and somehow make it very efficient.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.3.0 - 10.19.2026
                                        Wired up the Medeek API with the House Builder so that assemblies can be created with the following extensions: Wall, Truss, Foundation and Floor.
                                        Note that in order for the House Builder to work correctly you will need to upgrade your Wall, Truss, Foundation and Floor extensions to the latest versions (also released on 10.19.2026).
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Tutorial 8 - House Builder (19.42 min.)
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            I quickly realized I needed to add an Arc and a Circle tool.
                                            design.medeek.com
                                            • 6
                                            • 7
                                            • 7 / 7
