    Select *Most* Collinear Edges
    5 Posts 3 Posters 1.3k Views 3 Watching
    • M3DAmindM
      M3DAmind
      Is there a plugin to do the following?
      Select Edge
      Operation: read connected edges at selected edge vertices, add to selection the most collinear (In-line with) edge attached to vertice and disregard the rest. Repeat until no edges fall under a custom angle parameter (i.e. X=30°).
      An operation that would start and end as shown on the attached.
      I often use ThomThom's "Select Loop" from QuadFace Tools. Which is fantastic but won't compute in more chaotic meshes.
      Would be a game changer for anyone working in complex meshes/ landscaping/ etc.
      Hopefully I've just been missing out this whole time and it exists somewhere. I need to learn Ruby! Thanks for the help.
      • cottyC
        cotty
        You can use the path select tool from SketchUV (no automatic angle, but more manual control for difficult meshes). Or a similar tool from ProfileBuilder 3, if you have bought this great plugin.
        my SketchUp gallery
        • M3DAmindM
          M3DAmind
          Thanks! I've used SketchUV & PB2 in the past and completely avoided using the smart path selection tools. Helps, though it some conditions like an expansive sidewalk over hundreds of feet with changes in elevation, it'd be nice to have something instant like ThomThom's select loop with the properties in the OP. I'll have to learn Ruby. Thanks again.
          • sdmitchS
            sdmitch
            Select Edge
            Try this
            mod = Sketchup.active_model
            ent = mod.active_entities
            sel = mod.selection
            val = UI.inputbox(["Max Ang;"],[30.0],"Most Colinear")
            if val
              max_ang = val[0].degrees
              sel_edg = sel.first
              sel_edg.vertices.each{|start|
                found=true; nxt_edg = sel_edg
                while found
                  found=false;
                  if start.edges.length > 1
                    edges=start.edges-[nxt_edg];
                    vec = nxt_edg.line[1]
                    edg = edges.min_by{|e|vec.angle_between(e.line[1])}
                    ang = vec.angle_between(edg.line[1])
                    if  ang < max_ang || ang > Math;;PI-max_ang
                      sel.add edg;found=true;
                      start = edg.other_vertex(start)
                      nxt_edg = edg;
            http://sdmitch.blogspot.com/
            • M3DAmindM
              M3DAmind
              Wow, thanks. I need to hang out here more.
              It looks like I'm still hitting snags. The X/30° param would have to apply to the obtuse conditions, not acute conditions. It doesn't appear to be culling the right edges in some circumstances, and it's terminating early.
              Regardless, thanks for giving me something to tinker with at some point.
