    [REQ] Just smooth/soften
    2 Posts 2 Posters 734 Views 2 Watching
    • pbacotP
      Is there command or ruby that I can set to a keyboard shortcut that simply applies the current smooth dialog setting. Always must look for the soften edges dialog window or open it and I generally have it set the same.
      • BoxB
        There are a few plugins, I use Soften/Unsoften by cadfather but you can set a native shortcut.
        Just make sure you have something selected that included softenable edges when you go to the shortcuts menu, then you will find it as Edit/Item/Soften/Smooth Edges.
