    Medeek Electrical
    202 Posts 5 Posters 218.6k Views 5 Watching
    • medeekM Offline
      medeek
      Ultimately the number of included electrical devices and fixtures will probably exceed the amount of devices that I want to package as default with the plugin. My thinking on this is that down the road I can provide "packs" that the user can drop into the appropriate plugin library sub-folder to add more pre-configured components to the plugin.
      For example the commercial electrician or designer may want a much larger selection of fire and safety devices than the average residential designer. It doesn't make much sense to overly bloat the plugin size to include all of these specialized electrical components when most of the user base will not use them. Rather it makes sense to provide these electrical device "packs" as an upgrade type feature where the user decides for themselves which additional devices they would like to have available for their use.
      Also if enough people utilize this plugin it may also garner the interest of some of the manufacturers who then might be willing to provide some "official" models of their hardware (low poly preferably) for use within the plugin. Looking at a number of manufacturer's websites lately and there is only a handful that provide any sort of 3D models and those are usually in Revit. I would like to see more SketchUp models become available.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.0.3 - 04.03.2019
        • Added an advanced option for outlets to display the outlet height with the 2D symbol.
        http://design.medeek.com/resources/images/electrical_su42_800.jpg
        If this advanced option proves popular I can also add it to switches, low voltage outlets, safety devices (wall mounted), and light fixtures (wall mounted).
        This advanced option is per customer request.
        On my own electrical plans I typically don't call out the switch or outlet height however in some cases I have provided a height call out with GFCI outlets installed in the garage.
        design.medeek.com
        • medeekM Offline
          medeek
          First look at wall mounted (surface) fluorescent light fixtures:
          http://design.medeek.com/resources/images/electrical_su43_800.jpg
          First look at vanity light fixtures:
          http://design.medeek.com/resources/images/electrical_su44_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.0.4 - 04.06.2019
            • Added the following light fixture categories and symbols: Surface, Recessed, Vanity, Ceiling Fan, Ceiling Fan w/ Light, Fluorescent (Surface Mount).
            http://design.medeek.com/resources/images/electrical_su45_800.jpg
            Now that I've reworked the light fixture module it is much more conducive to adding in additional light fixture categories/types, at some point I may even allow the user to add in custom categories. I still need to add in the fluorescent suspended and recessed categories and their corresponding symbols. However, I usually won't add in a category until I have a minimum of one default fixture to place into the library for that category.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.0.4b - 04.07.2019
              • Added the following light fixture category and symbol: Fluorescent (Recessed).
              http://design.medeek.com/resources/images/electrical_su46_800.jpg
              Included fixtures are a 2x4 and 2x2 troffer.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.0.4c - 04.08.2019
                • Added the following light fixture category and symbol: Fluorescent (Suspended).
                http://design.medeek.com/resources/images/electrical_su47_800.jpg
                The only other major type of lighting that is missing is track lighting and possibly some variants of existing lighting types that indicate they are LED rather than fluorescent or incandescent.
                With fluorescent lighting there is a small text file in each library sub-folder that specifies the dimensions of the light fixture. Technically the numbers for each light fixture can be set to any value (width, depth, length), they are only used to provide the wireframe preview and help with the placement if you toggle the fixture justification. I will put out a tutorial on how to use these config files and setup your own custom fixtures.
                design.medeek.com
                • medeekM Offline
                  medeek
                  There seems to be a demand for the height callout next to the various electrical devices so I'm working at adding it to all wall mounted electrical devices.
                  First look at the height callout for switches:
                  http://design.medeek.com/resources/images/electrical_su48_800.jpg
                  design.medeek.com
                  • jujuJ Offline
                    juju
                    Nathaniel, maybe you should create a mechanism whereby the end-user can format their own symbols according to your method? So I can have my own custom models (and variety) but how they are structured needs to conform to your methods to work flawlessly with your extensions. You can keep your examples in there, for reference or if end-user doesn't want to go through process of creating their own.
                    • medeekM Offline
                      medeek
                      Version 1.0.4d - 04.09.2019
                      • Added an advanced option for switches and low voltage outlets to display the device height with the 2D symbol.
                      http://design.medeek.com/resources/images/electrical_su49_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Users can already create their own models for certain fixtures and then simply upload them into the appropriate library folder. For example there are currently nine sub-folders within the light_fixtures sub-folder:
                        ceiling_fan
                        ceiling_fan_light
                        fluorescent_recess
                        fluorescent_surface
                        fluorescent_suspended
                        recessed
                        surface
                        suspended
                        vanity
                        The user can put as many pre-configured *.skp files into these sub-folders as they like and the plugin can then utilize them.
                        Each of these light fixture types entails a specific 2D symbol which the plugin provides. Also the categories currently cannot be altered or added to. In the future I may devise a system whereby the user can add new categories for a device type and also their own custom 2D symbols, I'm just not there yet.
                        design.medeek.com
                        • jujuJ Offline
                          juju
                          this please
                          • medeekM Offline
                            medeek
                            Version 1.0.4e - 04.10.2019
                            • Added an advanced option for wall mounted light fixtures to display the device height with the 2D symbol.
                            http://design.medeek.com/resources/images/electrical_su51_800.jpg
                            I also resolved a minor bug with the placement of wall mounted light fixtures so I highly recommend upgrading to this latest release.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              First look at the electrical symbols legend generated by the plugin:
                              http://design.medeek.com/resources/images/electrical_su52_800.jpg
                              The secondary toolbar has the icon for generating the legend:
                              http://design.medeek.com/resources/images/electrical_ii_su_menu_active.jpg
                              The legend is parametric so every time you click the legend icon/tool it regenerates the legend based on what electrical devices are present in the model. You can also move (x, y or z) or rotate the legend and it will retain these new coordinates when it is regenerated.
                              Initially the legend is drawn at the origin but can be positioned at any location (and retained) by the user using SketchUp's native moved or rotate tools.
                              The overall size of the legend and its text and symbol size is driven by the parameter in the global settings, as is the font of the text which will match the font used by the electrical symbols in the model.
                              It also appears that you can use SketchUp's native scale tool to scale the legend and it will also retain this setting when regenerated.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                http://design.medeek.com/resources/images/electrical_su53_800.jpg
                                Outlets, Switches, Low Voltage and Load Centers.
                                I still need to add in lights, safety devices, Heaters and Vents.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.0.5 - 04.12.2019
                                  • Added the "Draw Legend" function to the secondary toolbar.
                                  • Enabled the ability to automatically create an electrical symbols legend for all electrical devices within the model.
                                  http://design.medeek.com/resources/images/electrical_su54_800.jpg
                                  After working my way down through the list of possible symbols I'm surprised to see that there are so many and the legend can get quite large.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    I think the real power in this plugin is not the ability to insert 3D components into your model, technically you don't even need a plugin to do this, just a bunch of pre-configured components (.skp files). The real strength is the automation of the 2D symbols and the parametrics of the plugin (allowing you to swap out devices types, colors, height and rotation). Now with the addition of a parametric symbols legend it automates yet another tedious task.
                                    I'm fairly happy with the way the legend has come out but for future work I may include a parameter in the global settings which allows the user to enable sub-titles (divides the legend into logical sections: outlets, switches, lights, etc...) as well as specify the number of columns that legend should be divided into, this becomes more of an issue when there are a lot of electrical symbols to display.
                                    I think some people would argue that I go too deep with my plugins (too many settings, parameters, options etc...) I would agree that if possible simple is often better. The goal is to make everything as simple as possible, but not simpler.
                                    On the flip side the addition of more options and parameters increases the amount of data or information that model contains and hence makes it more useful (BIM). Options also allow the user to further customize their workflow with the plugin and tailor it specifically to their needs. Many of the options I have added have been directly requested by users of the plugins
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      For those that are interested I will explain how the new "Draw Legend" tool works under the hood.
                                      First the plugin finds all of the groups in the model (active_entities, if no group or component is open for editing then this will be the same as entities at the root of the model).
                                      It then checks inside each of these groups and identifies the electrical groups that belong to the plugin (based on the group instance name). Once it has collected up all of the electrical groups in the model it then divides them into their appropriate categories: Outlets, Switches, Light etc...
                                      It then examines each sub-category and dives into the attributes library for each electrical device (group). The attributes library tells it what 2D symbol is associated with that particular device. It then creates a new list of symbols to draw for the legend for each category at the same time discarding or preventing duplicates.
                                      The symbols shown in the legend are drawn, for the most part, using the same methods as the symbols drawn for the actual devices however some of them have been altered slightly in order to customize them specifically for the legend.
                                      As you can see there is quite a bit going on under the hood. When a model gets large with hundreds of walls and possibly hundreds of electrical components generating the legend may take up to 30 seconds.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.0.6 - 04.15.2019
                                        • Added additional NEMA 240V receptacles into the Outlet module: NEMA 6-30R, NEMA 6-50R.
                                        These additional receptacles (and symbols) were per customer request.
                                        http://design.medeek.com/resources/images/electrical_su56_800.jpg
                                        http://design.medeek.com/resources/images/electrical_su57_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Tutorial 3: Electrical Symbols Legend
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Since adding the symbols legend I've had a number of requests for a tool to draw a schedule (similar to how I am drawing the legend).
                                            Now that I've got a fairly solid routine for pulling the electrical data (I will use much of this same code for the estimating tool) it isn't too big of a leap to draw a schedule.
                                            My question is what information do you need or want in this schedule, how do you want it laid out? Every device listed with its parameters or do I group like devices?
                                            Please give feedback in this regard. Also feel free to send me any sample electrical schedules that I can utilize as references.
                                            If I know what I want to output I can probably knock this out in 2-3 hours, most of the underlying code is already in place.
                                            design.medeek.com
                                            • 6
                                            • 7
                                            • 10
                                            • 11
                                            • 5 / 11
