    Insert a new instance of existing component already in model
    4 Posts 3 Posters 1.5k Views 3 Watching
    • J
      JGA
      Is there a plugin available that will allow you to right-click on an existing instance of a component and add another copy?
      I know it's a fringe request, but with a lot of components, it can be a hunt to find the needle in the component browser pile.
      Regards,
      JGA
      • BoxB
        A bit lost, move tool and ctrl will make a new copy.
        Could you explain a use case that we might see a way to help.
        • T
          TBoy
          thomthom: Repeat Place Component
          Usage: Right click a component instance, choose Place Component - you can now place the component repeatedly
          https://sketchucation.com/pluginstore?pln=tt_place_component
          • J
            JGA
            TBoy, many thanks for the link.
            Box, you’re right, but AutoCAD has a similar command (addselected), which can save a bit of hunting and trying to locate the insertion point of a component.
            Regards,
            JGA
