    HtmlDialog position
    1 Posts 1 Posters 3.2k Views 1 Watching
    • bomastudioB
      bomastudio
      In a dual monitor config, how can I check in which monitor SU is running, so I can locate correctly a HTMLDialog?
      For example, immagine the following config:
      MONITOR 1 on right
      MONITOR 2 on left (where SU is running)
      and the following code
      dialog = UI;;HtmlDialog.new({
      			  ;dialog_title => "MyWindow",
      			  ;scrollable => true,
      			  ;resizable => true,
      			  ;width => 300,
      			  ;height => 250,
      			  ;left => 0,
      			  ;top =>0,
      			  ;style => UI;;HtmlDialog;;STYLE_UTILITY
      The dialog will apper outside from SU, in the MONITOR 1 instead of MONITOR 2 where is SU.
