    Divide curve - Anyone interested ?
    15 Posts 9 Posters 1.8k Views 9 Watching
    • Didier BurD Offline
      Didier Bur
      Please go here for downloading the plugin:
      https://sketchucation.com/forums/viewtopic.php?f=323&t=70027
      Recently I had to split many curves in a model, and found it tedious and boring. So I wrote a quick script to speed up the process.
      If anyone interested, I can polish the plugin and release a tool which would look like the native "divide" option (that works only on edges and arcs). It will work for open or closed curves (polylines) and polygons.
      DB
      • BepB Offline
        Bep
        Of course i am interested!
        I wasn't even aware it was missing from the standard tools.
        But then, nobody will know which tool they miss until they need it.
        "History is written by the winners"
          Fredo has some polylines dividers inside Bezier curves but not the same concept!
          • soloS Offline
            solo
            I'd like to be able to select a bunch of connected lines and divide them into equal parts, with the new Clothworks plugin this will be very useful for ropes and wires. So, yeah, this gets my vote.
            http://www.solos-art.com
              cuttingedge
              yeah it will be handy... 😄
              • srxS Offline
                srx
                Would be nice 😄 Something like interactive http://sketchucation.com/forums/viewtopic.php?f=323&t=66492
                www.saurus.rs
                  Didier Bur
                  @srx:
                  Yes the tool will be interactive exactly like the "divide" option of the context menu, the red points are moving along the curve when you hover the curve with the cursor.
                  DB
                    dtrarch
                    Please Didier
                      rparsons
                      That would be awesome. And as always, thank you for all you do.
                        rv1974
                        There are some dilemmas:
                        Will it build a new curve with straight segments between new vertices or it'd just split existing curve keeping existing segmentation? Ideally it'd be nice to give 2 options.
                        How it'd treat 'important ' say 90 degr. corners?
                        • srxS Offline
                          srx
                          The curves would be easy to explode later.
                          www.saurus.rs
                            rv1974
                            We all know to explode. I asked something different. Imagine L-shaped (2 segment, 3 vertices ) curve. What methodics will be choosen to divide it to 3?
                              Didier Bur
                              @rv1974:
                              in this case you'll have 3 possible results (depending on the option you select): 4 lines, 3 curves, or a single curve with 5 vertices.
                              DB
                                rv1974
                                Or single 3-segment curve with 4 vertices (original middle vertices will go away)??
                                  Didier Bur
                                  DB
