    โš ๏ธ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 95.9k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      The version 1.5.7 of the PBR plugin:
      • Exports sun light direction according to settings defined in Shadows panel.
      • Fixes three little bugs about: ME tooltips, SU back faces & Viewport loader.
      Download latest PBR plugin from the SketchUcation PluginStore.
      • samuel_tS Offline
        samuel_t
        The version 1.5.8 of the PBR plugin:
        • Exports sun light intensity according to Light parameter defined in Shadows panel.
        • Fixes a bug affecting some models: Viewport doesn't open and SketchUp freezes โ—
        • samuel_tS Offline
          samuel_t
          The version 1.5.9 of the PBR plugin fixes URL of required plugin (glTF Exporter).
            DH2002
            First, Is this Plugin works for Mac OS SketchUp 2018 Pro?
            I managed to Install it and I have SimLab USDZ exporter Installed that works fine.
            After I install this Plugin SketchUp crashes, cant even save or load any object?
            I can draw a new mesh and even open this plugin, Load maps etc but when the try export files Aplication Crashes?
            My SketchUp the doesent work properly until I deinstall this Plugin.
            / Daniel
            • samuel_tS Offline
              samuel_t
              / Daniel
              First, sorry for this late reply:
              This plugin is compatible with SketchUp 2017-2021 for Windows and should be compatible with SketchUp 2017-2021 for macOS.
              If this plugin crashes when you export model as glTF file, you can try to in order:
              1. Open "Window > Ruby Console".
              2. Copy-paste below code:
              PBR;;GlTF.export
              1. Press enter to execute above code.
              2. Send me a screenshot.
              • samuel_tS Offline
                samuel_t
                The PBR 2.x plugin for SketchUp will support real-time ray tracing. Work in progress:
                • pabloariasP Offline
                  pabloarias
                  Hi. From a month, more or less, I got a popup when SU starts that said something about a newer version 4.2.6 from this plugin and opens this SketchUcation page when message accepted. But I see no news here about newer releases of this plugin. Does anybody here tell me what's wrong?
                  Pablo Arias
                  SketchUp trainer
                  V-Ray licensed trainer
                  • chonC Offline
                    chon
                    Hello,
                    I think this message is about the last version of SketchUcation ExtensionStore ๐Ÿ˜‰
                    SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
                    • samuel_tS Offline
                      samuel_t
                      @chon said:
                      Hello,
                      Yes, it makes sense! ๐Ÿ˜„
                      • samuel_tS Offline
                        samuel_t
                        Hi Pablo.
                        4.2.6 ? ๐Ÿ˜• I'm working on the 2.x version of the PBR plugin but the latest public version available at SketchUcation is 1.5.9.
                        • Didier BurD Offline
                          Didier Bur
                          Hi Samuel,
                          First thanks for this great plugin (just like all of your other goodies).
                          Some questions about the materials:
                          -what is the difference between the heightfield map and the normal map features ?
                          • how to get an occlusion map based on a jpg texture ?
                          I'm starting some tests and amazed with the results ๐Ÿ˜‰
                          Thanks for your time.
                          DB
                          • samuel_tS Offline
                            samuel_t
                            @didier bur said:
                            Hi Samuel,
                            Hi Didier,
                            That's very kind! ๐Ÿ˜„
                            The height map in the PBR 1.x plugin is a parallax occlusion map. The height map is a grayscale image which simulates a "deep relief". You can use a displacement map from Poly Haven (for example) as a height map. Whereas the normal map encodes the "bas-relief" in the RGB channels of an image...
                            Handmade or automatic? Some softwares can autogenerate an [ambient] occlusion map from a diffuse texture...
                            Stay tuned ๐Ÿ˜‰ The PBR 2.x plugin should reach photorealism.
                            You're welcome!
                              Didier Bur
                              Hi Samuel,
                              Thanks for your answers.
                              I'm curious to know why each time I launch Sketchup I get the message:
                              It loads the Web page where I can dowload version 1.5.9. ๐Ÿ˜ฎ
                              Where can I find version 4.2.6 ?
                              Best regards,
                              DB
                              • chonC Offline
                                chon
                                Hi Didier,
                                I think you've got the same problem as on this post :
                                @chon said:
                                Hello,
                                  Didier Bur
                                  Merci !
                                  ๐Ÿ‘
                                  DB
                                  • samuel_tS Offline
                                    samuel_t
                                    The PBR 2.x plugin for SketchUp could render the atmosphere with volumetric clouds in real-time.
                                      A partir de quelle version c'est compatible? โ˜€
                                      • samuel_tS Offline
                                        samuel_t
                                        Hello Pilou ๐Ÿ˜„
                                        It should be compatible with SketchUp 2017+.
                                          ๐Ÿ‘
                                          • 6
                                          • 6 / 6
