    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 110.4k Views 14 Watching
    • pabloariasP
      pabloarias
      Hi. From a month, more or less, I got a popup when SU starts that said something about a newer version 4.2.6 from this plugin and opens this SketchUcation page when message accepted. But I see no news here about newer releases of this plugin. Does anybody here tell me what's wrong?
      Pablo Arias
      SketchUp trainer
      V-Ray licensed trainer
      • chonC
        chon
        Hello,
        I think this message is about the last version of SketchUcation ExtensionStore ๐Ÿ˜‰
        • samuel_tS
          samuel_t
          @chon said:
          Hello,
          Yes, it makes sense! ๐Ÿ˜„
          • samuel_tS
            samuel_t
            Hi Pablo.
            4.2.6 ? ๐Ÿ˜• I'm working on the 2.x version of the PBR plugin but the latest public version available at SketchUcation is 1.5.9.
            • Didier BurD
              Didier Bur
              Hi Samuel,
              First thanks for this great plugin (just like all of your other goodies).
              Some questions about the materials:
              -what is the difference between the heightfield map and the normal map features ?
              • how to get an occlusion map based on a jpg texture ?
              I'm starting some tests and amazed with the results ๐Ÿ˜‰
              Thanks for your time.
              DB
              • samuel_tS
                samuel_t
                @didier bur said:
                Hi Samuel,
                Hi Didier,
                That's very kind! ๐Ÿ˜„
                The height map in the PBR 1.x plugin is a parallax occlusion map. The height map is a grayscale image which simulates a "deep relief". You can use a displacement map from Poly Haven (for example) as a height map. Whereas the normal map encodes the "bas-relief" in the RGB channels of an image...
                Handmade or automatic? Some softwares can autogenerate an [ambient] occlusion map from a diffuse texture...
                Stay tuned ๐Ÿ˜‰ The PBR 2.x plugin should reach photorealism.
                You're welcome!
                • Didier BurD
                  Didier Bur
                  Hi Samuel,
                  Thanks for your answers.
                  I'm curious to know why each time I launch Sketchup I get the message:
                  It loads the Web page where I can dowload version 1.5.9. ๐Ÿ˜ฎ
                  Where can I find version 4.2.6 ?
                  Best regards,
                  DB
                  • chonC
                    chon
                    Hi Didier,
                    I think you've got the same problem as on this post :
                    @chon said:
                    Hello,
                    • Didier BurD
                      Didier Bur
                      Merci !
                      ๐Ÿ‘
                      DB
                      • samuel_tS
                        samuel_t
                        The PBR 2.x plugin for SketchUp could render the atmosphere with volumetric clouds in real-time.
                          A partir de quelle version c'est compatible? โ˜€
                          • samuel_tS
                            samuel_t
                            Hello Pilou ๐Ÿ˜„
                            It should be compatible with SketchUp 2017+.
                              ๐Ÿ‘
                              • 6 / 6
