    Trying to get a string
    4 Posts 3 Posters 2.9k Views 3 Watching
    • W Offline
      WEB
      In a Ruby script, I would like to set a variable equal to the user's input from the keyboard with no inputbox or dialog slowing things down. It's easy as can be in Ruby: myVariable = gets. Darned if I can figure out how to do it in SketchUp Ruby.
      I'm an absolute newb at this, so I'd appreciate any help you can give.
      • fredo6F Offline
        fredo6
        I am afraid that you have to use a dialog box. gets does not work in Sketchup Ruby.
        There are several methods:
        1. Use the UI.inputbox method. This is short to code (a few lines).
        2. Use a WebDialog or HTMLDialog, much longer to code, but you have full freedom on formatting.
        3. If you develop an interactive "Tool" (i.e. class Sketchup::Tool) and you need a numeric input, you can use the VCB input (method UserText())
        Fredo
        • W Offline
          WEB
          Thank you. That explains why I couldn't figure out how to do it. On to Plan B!
          • Dan RathbunD Offline
            Dan Rathbun
            The real reason is because standard IO has been redirected to SketchUp's Ruby Console.
            I'm not here much anymore.
