    [Plugin] Souvenir - v2.2b - 07 Apr 24
    34 Posts 10 Posters 24.8k Views 10 Watching
    • F Offline
      Freebird Interiors
      Hi , I've been looking for a task management system within Sketchup to use between different computers and team members. Where does Souvenir save the task list, and can I change the location to a shared google drive folder to both team members stay up to date? Thanks
      • fredo6F Offline
        fredo6
        Currently, SU Tasks are stored in a file
        C:\Users<username>\AppData\Local\LIBFREDO6_DATA_Dir\Souvenir\Souvenir_tasklist_file_SU.txt
        But I could offer the option to choose the location of the directory.
        Fredo
        EDIT: as you are on Mac, the path is different. The best is to open the Ruby console and type
        F6_Souvenir.appdata_dir. The file name is Souvenir_tasklist_file_SU.txt.
        • fredo6F Offline
          fredo6
          NEW RELEASE: Souvenir v1.8d - 28 Jul 19
          Souvenir 1.8d gives the possibility to specify a custom directory for saving SU tasks. This allows to potentially share these SU Tasks across different computers. The custom directory is entered in the Default Parameters of Souvenir.
          Souvenir 1.8d requires LibFredo6 9.1b or above
          IMPORTANT: make sure you install the latest version LibFredo6 v9.1b or above.
          See plugin home page of Souvenir for Download of Souvenir.
          Main Post of the Souvenir thread on this forum
          • fredo6F Offline
            fredo6
            NEW RELEASE: Souvenir v2.0a - 25 May 20
            Requirements
            • LibFredo6: v10.5a
            Souvenir 2.0a is a maintenance release for bug fixing and Mac compatibility.
            • jujuJ Offline
              juju
              @Fredo6, did you skip Souvenir version 1.9?
              • fredo6F Offline
                fredo6
                That's a possibility...
                  db11
                  @Fredo6
                  I find Souvenir very useful in logging and tracking issues/to do's in SU, so many thanks for creating it!
                  Two additional features would really increase its utility (at least for me):
                  1. Add an 'Import' function:
                    I have pre-existing workflow checklists that I would like to import as csv (preferably) or text. An import function would allow me to preload my checklist at the start of each project.
                  2.Add a 'Filter' function to the Tasklist:
                  It would be really useful for managing longer lists to be able to filter items.
                  While my Excel-based workflow lists are fully tagged (to work with Excel's Autofilter) it would be easy for me to concatenate the tags with the list items before import, then use the filter to narrow the list by context. A filter function would be helpful even without an import capability.
                  Thanks for the consideration and for all your amazing efforts and output.
                    db11
                    @Fredo6
                    I seem to have encountered a bug:
                    Button bar missing at bottom of Model Tasklist, as seen in this screenshot:
                    I'm running MacOS 10.13.6 on a MacBook Pro (13" Retina, Mid 2014) with a 34" Dell Ultrawide (U3415W) display.
                    Any idea what's causing it?
                    • fredo6F Offline
                      fredo6
                      NEW RELEASE: Souvenir v2.1a - 20 Nov 20
                      Requirements
                      • LibFredo6: v11.3a
                      Souvenir 2.0a is a maintenance release for SU2021 compatibility.
                        masloprojekt
                        Hello,
                        this one is great. The task list in SketchUp is exactly where it should be. I would also be more than happy if there would be an import function.
                        Thank You!
                        • fredo6F Offline
                          fredo6
                          This can be done, but if you maintain your task list outside Sketchup, then what is the benefit?
                            db11
                            I would like to second the request for an import function. It would be very helpful for my workflow to be able to import csv's from my Excel project dashboard.
                            • fredo6F Offline
                              fredo6
                              NEW RELEASE: Souvenir v2.2a - 02 Apr 24
                              Requirements
                              • LibFredo6: v14.3a
                              Souvenir 2.2a is a maintenance release for:
                              • Future compatibility.
                              • fredo6F Offline
                                fredo6
                                NEW RELEASE: Souvenir v2.2b - 07 Apr 24
                                Requirements
                                • LibFredo6: v14.3a
                                Souvenir 2.2b is a maintenance release for:
                                • SU2024
                                • Fix in Model history
                                • 2 / 2
