    Line Quantity Reducer ?
    3 Posts 2 Posters 903 Views 2 Watching
    • MatteM
      Matte
      Hi All,
      What would you recommend as the best way to reduce the number of line segments in a 3D Sketchup model? I import stuff modify it and something that looks like 1,000 lines comes up with 245,000 small line segments when I run the "Solid Inspector" plugin! I'm willing to accept a little less detailed model to reduce this to something (usable). I can always redraw a few areas if too much is cleaned up. The 3D models are for export to .STL so I can run it through a 3D printer.... It doesn't like to print 245,000 little lines? Thanks in advance for any advice you may have.
      Mattee
      • R
        rv1974
        tt edge tools
        • MatteM
          Matte
          Thanks !!!
