    Measure a dxf for me?
    15 Posts 6 Posters 2.7k Views 6 Watching
    • Joe WoodJ Offline
      Joe Wood
      I don't have any way to measure dxf files, could someone measure this plumb cut and tell me if it is 7 1/2" ??
      Long Common.dxf
      Joe Wood
      woodsshop.com/
      • Joe WoodJ Offline
        Joe Wood
        whoops, it should be ~7 13/16" ! So is it, on this dxf??
        Joe Wood
        woodsshop.com/
        • Joe WoodJ Offline
          Joe Wood
          I just tried importing it into SUp but it came in way too large.
          Joe Wood
          woodsshop.com/
          • Joe WoodJ Offline
            Joe Wood
            yeah that's what the imported into SUp file measured at, 7' 9!
            Joe Wood
            woodsshop.com/
              driven
              there is an error on the end and results depend on how you fix it...
              john
              • tuna1957T Offline
                tuna1957
                Joe, just checked it in my cad program and giving me a line length of 7' - 6" something..... good grief...... don't know if it's the file or something I did..... haven't used my 2D cad in freaking ages..... maybe one of the wizards will be along and sort it out.
                Edit - Just imported it into SU and coming in at same size as it did in my cad program..... must be the file.... no clue ?
                • ecatiE Offline
                  ecati
                  In SketchUp this is how it looks.
                  • Joe WoodJ Offline
                    Joe Wood
                    Darn I just saw that too! Luckily it didn't come out in the pieces I had cut by CNC!
                    thanks for the help peeps!
                    say, is there any freeware I can use to make these measurements on dxf files?? I have AutoDesk DWG True View but can't figure out how to measure with it.
                    Joe Wood
                    woodsshop.com/
                    • BepB Offline
                      Bep
                      301 Moved Permanently
                      (www.3ds.com)
                      "History is written by the winners"
                        A free very cool one!
                        Pcon Planner 😎
                        Has Import / Export DXF, DWG,SKP etc... πŸ€“ So very cool for SU Make πŸ˜‰
                        And many other marvelous things! β˜€
                        As Imperial unities is Chiness for me make your own conversions! πŸ˜‰
                        Here unity : Meter
                        • tuna1957T Offline
                          tuna1957
                          Here's a question to the architects and others who do a lot of dwg/dxf file imports. Maybe it will help out folks like me and Joe down the road.
                          Why did this file import into SU at such an abnormal size? Straight line length of rafter was over 200'. Joe and I both experienced the same thing.
                          A side note ... the file imported into my 2D cad program the same huge size. Never have had an issue with auto cad files in the past with that software.
                          Just curious and maybe help out others down the road that don't import dwg's of dxf's very often.
                          • Joe WoodJ Offline
                            Joe Wood
                            Hey Pilou, can I change the units to Imperial in that Picon Planner?
                            Joe Wood
                            woodsshop.com/
                              Of course yes! It's not marvelous ? β˜€
                              I had made the Inverse : Imperial to Metric at the importation! πŸ’š
                              It's a true gem! 😎
                              Here in French but you have some languages! (14) 😲
                                driven
                                you need to set the import units to match the files units...
                                I normally have it set to meters, but changed it to inches for this one...
                                john
                                • tuna1957T Offline
                                  tuna1957
                                  driven , thanks for clarifying that.... click the options button in the import drop down window... a definite d'oh moment for me !
