    [REQ] Inflate Components...
    3 Posts 2 Posters 548 Views 2 Watching
      I have these components on the left
      How make a "Strip" around each for have the red ones? (here in 2D but will fine also in 3D)
      (When i say a strip : just rectangle becomes larger inflate by 0.05 m)
      A sort of Scale ?...
      Seems "Scale Rotate Multiple" by Chris Fullmer can make the trick but curioussly not! ๐Ÿ˜ฎ
      So have you a little trick or a little plugin for that? ๐Ÿ˜„
      strip_ component.skp
      • sdmitchS Offline
        sdmitch
        Try this
        @mod = Sketchup.active_model
        @sel = @mod.selection
        cmps = @sel.grep(Sketchup;;ComponentInstance)
        cmps.each{|ci|
         ctr = Geom;;Point3d.linear_combination(0.5,ci.bounds.corner(0),0.5,ci.bounds.corner(3))
         xscl = (ci.bounds.width+0.1.m)/ci.bounds.width
         yscl = (ci.bounds.height+0.1.m)/ci.bounds.height
         tr = Geom;;Transformation.scaling(ctr,xscl,yscl,1.0)
         ci.transform! tr
        http://sdmitch.blogspot.com/
          Excellent! ๐Ÿ‘
          Can you put this in a little plugin with one input variable measure?
          And something for any forms? Separated Components on the left: Gap = 0.2m
          Here big size of scale for avoid overcrossed arc-lines!
          My workflow for create separate Components from a general drawing (above previous post from Protrude by Jim)
          • Multiple Offset by Remus
          • Select Only Simple Face by TIG ?
          • Copy move
          • Loose to Group by Chris Fulmer
          • Groups to Components by ThomThom
          • new code Inflate By Sdmitch (works fine for quads forms) Not yet for these forms above! ๐Ÿ˜‰
          But maybe some one has a more tricky tip?
          little_gapv6.skp
