    How can I get a direct link to a plugin's Documentation tab?
    4 Posts 3 Posters 705 Views 3 Watching
      slb_jwm
      I would like to make a direct link from the Help page to the [More info] Documentation tab on SketchUcation.com for the plugin Angular Dimension 2.
      When I view the Documentation tab after following the link from the plugin title page to "More Info", the displayed URL doesn't change from http://sketchucation.com/plugin/1879-angular_dimension_5 which in a new browser window just opens the plugin title page itself.
      And I've used Developer Tools to look at the code for that and other links internal to the More Info tabs, but can't quite see how it is invoked.
      Is it possible to go directly to this page from an href link in the Help page itself? If so, how?
      Opening part of Documentation page
      • G Offline
        Gábor
        @slb_jwm: At the moment it is not possible to link individual tabs directly. But thank you very much for the idea we'll take a look into it and might implement this feature.
          Jim
          Why not generate a local copy, open it in a WebDialog, and distribute with the extension? It'll work offline and save SketchUcation a little server cost.
            slb_jwm
            Jim, that was my first thought. But then I wondered if I could go direct, so I wouldn't need to maintain a separate MarkDown document for Sketchucation, and a duplicate HTML document for distribution. And any updates to the SketchUcation site would be visible to people who had the plugin, but maybe hadn't seen or downloaded an update.
            Gabor, thanks for considering a feature update, and for confirming that it isn't currently possible.
            I'll do what Jim suggests in the meantime.
