    User ending a program
    6 Posts 2 Posters 1.8k Views 2 Watching
    • K
      ktkoh
      I have used "exit" in my joint tool program for cases where the user's selection was in error or when a data form asked for input that the user did not have so they selected cancel. I do see that this produces an error message in the ruby console so I am asking if this is unacceptable practice? I found that if the space bar is pressed the selection tool is activated and my tool dropped but Sketchup.send_action "selectSelectionTool:" does not do anything.
      Keith
      • Dan RathbunD
        Dan Rathbun
        @ktkoh said:
        I have used "exit" in my joint tool program ...
        Is this an external script running in a system Ruby process, or a SketchUp extension running in an embedded Ruby subprocess ?
        Raising a SystemExit exception has only good use in a system Ruby script, and no good use in an embedded Ruby subprocess.
        So, yes, within SketchUp, it is poor practice. It is better to raise a RuntimeError exception with a custom message, or create your own exception subclasses within your extension namespace.
        Here is a simple example:
        Custom_Exception_SubClasses.rb
        # encoding ; UTF-8
        # A simple example of creating your own Exception
        #  sub-classes inside your own namespace modules.
        # fail() is an alias for raise(), and most coding style guides
        # prefer that fail() is used when first causing an exception,
        # and raise() is used when re-raising a current exception within
        # a rescue block.
        module Author # <--<<< Change to unique toplevel namespace module.
          module SomeParticularPlugin
            VERSION = '1.0.0'
            InputCancellation = Class.new(RuntimeError)
            InvalidSelection  = Class.new(RuntimeError)
            NoGroupsSelected  = Class.new(RuntimeError)
            # In this module we assume that the module variables; @@prompts,
            #  @@defaults, @@choices & @@caption have already been defined.
            def get_input(selection_set)
              # First, make a decision about the selection set;
              if selection_set.empty?
                fail(InvalidSelection,"selection is empty!")
              elsif !selection_set.single_object?
                fail(InvalidSelection,"selection not single object!")
              else
                grps = selection_set.grep(Sketchup;;Group)
                if grps.empty?
                  fail(NoGroupsSelected,"no groups are selected!")
              data = inputbox(@@prompts,@@defaults,@@choices,@@caption)
              # false if the user cancels
              fail(InputCancellation,"user cancelled") if !data
              # otherwise data is an array of values
            rescue InputCancellation => err
              UI.messagebox("Stop; #{err.message}")
              return nil
            rescue InvalidSelection => err
              UI.messagebox("Selection Error; #{err.message}")
              return false
            rescue => err # any other exception
              # recover gracefully
              UI.messagebox("Error; #{err.message}")
              return false
            else # no errors
              # code to execute when input is valid
              return data
            end ###
          end # specific plugin module
        end # outermost namespace module
        I'm not here much anymore.
        • K
          ktkoh
          Thanks Dan that really helped me. I had never run across the term fail() and was able to research this in the ruby help files I use. I have tested it in my program and find it works as you described.
          Keith
          • Dan RathbunD
            Dan Rathbun
            Cool! That was the purpose.
            Kerenl#fail() is just an alias for Kernel#raise().
            (I explained this in the file comments, and why I use it, instead of raise.)
            I just noticed an error, although the example should still work.
            Line 38 was meant to be:
            data = UI.inputbox(@@prompts,@@defaults,@@choices,@@caption)
            Currently it is:
            which uses the global inputbox() retry wrapper method defined in " %(black)[Tools/sketchup.rb]". So then the " %(black)[sketchup.rb]" file must be loaded first.
            If y'all prefer, you can call the UI.inputbox() module method directly and bypass the retry wrapper.
            • Dan RathbunD
              Dan Rathbun
              So, you realize that although you could handle this scenario with very long cluttered if ... elsif ... else constructs, likely with a bunch of nested if statements,... that would be hard to maintain and use more lines.
              This way condenses the code, and makes it more readable, and easier to maintain.
              • K
                ktkoh
                The program I used as a model when starting used that method. However as I added more functions it became almost impossible to find how to get out to the end of the mouse click down def.
                Keith
