    Geometric Calculation with ruby
    6 Posts 3 Posters 885 Views 3 Watching
      davesexcel
      ![11.25" width](/uploads/imported_attachments/Rd18_StringerWidth.jpg "11.25" width")
      I am trying to get a point so that my group ends up being 11.25" wide.
      ` Sketchup.active_model.entities.clear!
      b=51.5
      d=46.5
      e=0.5
      rise=7.75
      run=10
      #<<<routed stringer
      group = ent.add_group(); group.name="Routed Stringer"
      ent6 = group.entities
      pts = []
      pts[0] = [0,b-(1+e),d]
      pts[1] = [0,b-(4+e),d]
      pts[2] = [0,-3, rise]
      pts[3] = [0, -3, 0]
      pts[4] = [0,(run+2.5)*0.4256, 0]
      pts[5] = [0, b-(1+e), (d-12 )]
         #add the face to the entities in the model
      face = ent6.add_face pts`
      The calculation I came up with will only work when the variables are a specific value, has anybody an idea how to calculate the points, so my width stays 11.25 with variable inputs?
      • sdmitchS Offline
        sdmitch
        Are b,d,e,rise,run all variables?
        http://sdmitch.blogspot.com/
          davesexcel
          Hello,
          b & d are variables, rise and run are calculated from b & d.
          for this example rise=d/6 and run=(b-(1+e))/5
          I just put in the numbers so the code can easily be copied and run
          • sdmitchS Offline
            sdmitch
            @davesexcel said:
            Hello,
            As I see the problem then is that points 4 & 5 need to be calculated.
            mod = Sketchup.active_model
            ent = mod.active_entities
            sel = mod.selection
            vue = mod.active_view
            vars = UI.inputbox(["b;","d;"],[51.5,46.5],"Routed Stringer")
            if vars
              b,d = vars; e = 0.5
              run = (b-(1+e))/5.0
              rise = d/6.0
              #<<<routed stringer
              pts = []
              pts[3] = [0, -3, 0]
              #calculate pts 4 & 5
              vec = pts[2].vector_to(pts[1])
              v = vec.axes[1].reverse
              tpt = pts[2].offset(v,11.25)
              pts[4]=Geom.intersect_line_line [pts[3],[0,1,0]],[tpt,vec]
              #pts[4] = [0,(run+2.5)*0.4256, 0]
              pts[5] = Geom.intersect_line_line [pts[0],[0,0,1]],[tpt,vec]
              #pts[5] = [0, b-(1+e), (d-12 )]
              davesexcel
              Thanks a lot, I need to work on
              Geom.intersect_line_line more
                Using the Geom methods, and the methods on Geom::Point3d, Geom::Vector3d as much as possible is beneficial for performance. The SketchUp API methods are implemented in C++ and will be faster than pure Ruby code.
