    [REQ] Distance of 2 groups/components
    4 Posts 3 Posters 623 Views 3 Watching
      chrisik
      Is there a plugin out there that can quickly measure the distance of the midpoints of two selected groups and/or components in all 3 dimensions and direct distance. Or is somebody out there that can write this little plugin? thanks.
      Example of the plugin
        Center Point All by TIG
        Adds a centerpoint to anything that's selected - Group, ComponentInstance, Line, Circle, Face etc
        then you can or
        • sdmitchS Offline
          sdmitch
          Something like this? First select 2 components and/or groups then right click on either one and select 'Calc xyzd'.
          unless file_loaded?((__FILE__))
          	UI.add_context_menu_handler do |menu|
          		sel = Sketchup.active_model.selection
          		if (sel[0].is_a?(Sketchup;;ComponentInstance)||sel[0].is_a?(Sketchup;;Group))
          			if (sel[1].is_a?(Sketchup;;ComponentInstance)||sel[1].is_a?(Sketchup;;Group))
          				menu.add_separator
          				menu.add_item('Calc x,y,z,d') {
          					center0 = sel[0].bounds.center
          					center1 = sel[1].bounds.center
          					x = Sketchup.format_length((center1.x-center0.x).abs)
          					y = Sketchup.format_length((center1.y-center0.y).abs)
          					z = Sketchup.format_length((center1.z-center0.z).abs)
          					d = Sketchup.format_length(center0.distance(center1))
          					UI.messagebox "x = #{x}\ny = #{y}\nz = #{z}\nd = #{d}"
          	file_loaded((__FILE__))
          http://sdmitch.blogspot.com/
            chrisik
            πŸ‘ YES. Thank you very much. This is a big timesaver for me. πŸ˜„
