    Reload or recharge
    6 Posts 3 Posters 908 Views 3 Watching
      DDS
      what is the ruby command to execute the command reload or recharge (like the right mouse click).
      • Dan RathbunD Offline
        Dan Rathbun
        I think you mean Component "Reload..." when right-clicking on an instance.
        (1) You might set a keyboard accelerator (shortcut) like "CTRL+R".
        (2) There is no persistent automation integer ID for this command (that I can find.) The context menus are created "on-the-fly" as needed, and the menu commands are created just before the menu is displayed, and destroyed soon after the menu disappears. (So the "Reload..." command ID is always changing.)
        (3) There is no reload API method. But requests have been filed for one. I think there have been some workaround snippets posted in the forums. (Do a search. This was talked about just in the past week.)
        (4) I do not see a Sketchup::send_action() string for it listed in this topic:
        http://sketchucation.com/forums/viewtopic.php?t=34840
        I'm not here much anymore.
          DDS
          yes, it : "Reload..." when right-clicking on an instance
          I'll look for workaround snippets posted in the forums.
            What is the context of this question? Wondering is there is an alternative way to solve what you are looking for.
              DDS
              I want to create a button that changes the selected component (+ all similar) by another based on its name.
                DDS
                Here is my solution 😎
                				selectionObjectTemp = Sketchup.active_model.selection.to_a
                				if selectionObjectTemp.length == 0
                					selectionTemp = nil
                				else
                					selectionTemp = selectionObjectTemp
                				if @definitions[definitionAImporter]
                					definition = @definitions[definitionAImporter]
                				else
                					composantPath = File.join(@libPath,"#{definitionAImporter}.skp")
                					if File.exist?(composantPath)
                						definition = @definitions.load composantPath
                					else
                						UI.messagebox "le chemin n'existe pas; #{composantPath}"
                				if selectionTemp != nil
                				selectionTemp.each{|entitie|
                					if entitie.is_a? Sketchup;;ComponentInstance
                						entitie.definition = definition
