    Mig-31 Foxhound
    7 Posts 3 Posters 1.3k Views 3 Watching
    • cheddaC
      chedda
      Mig-31 Foxhound
      Sketchup & Maxwell Render.
      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
      • cheddaC
        chedda
        Yes i never do post production, i can make the materials more reflective quite easily however i believe most aircraft bodies are quite matt in appearance. Thanks for the comment yes Maxwell can output all ranges of images and depths i have the full suite i assume the plugin alone also has these features. The free version has some limitations like resolution.
        • R
          rv1974
          Nice, but your materials need some extra reflection I guess.
          You religiously avoid postproduction? Does Maxwell for SU output 32bit?
          http://alieneye.livejournal.com/124723.html
          • cheddaC
            chedda
            I made the fuselage parts of my next post a touch more reflective RV.
            • cheddaC
              chedda
              I just used a texture and a normal map i didn't use a specular i think it would help.
              • R
                rv1974
                http://pix.avaxnews.com/avaxnews/fb/70/000070fb.jpeg
                In Su-47 case, do you put some bitmaps in reflection slot?
                http://www.neilblevins.com/cg_education/flat_metallic_surfaces/flat_metallic_surfaces.htm
                And usually it's a good idea to put reflective pass (blending mode and opacity- by your taste) above beauty pass in the Post.
                • Bryan KB
                  πŸ‘
