    [Plugin] PomPi (Pompous Piping 2016 RC2018 )
    47 Posts 10 Posters 44.2k Views 10 Watching
    • FrederikF Offline
      Frederik
      @dezmo said:
      I'm in the middle of nowhere... in industrial area. (Videbรฆk close to Herning)
      Aahhh... In Jylland... Far away from Copenhagen...
      But you're not Danish - right...?!
      Could have been fun to meet you and have a cup of coffee or a beer...
      Aahhh welll... Perhaps another time...
      Cheers
      Kim Frederik
        dezmo
        I'm Hungarian, currently living in Germany and traveling a lot. Maybe one time we can have some coffee... ๐Ÿ˜Ž
        Man can do everything. Only a matter of time and money.
          dezmo
          Update in the first post:
          Changes: (2016_0711_2005)
          • The HTML UI tuned (horizontal UI removed)
          • User input check is massively improved
            Note the input fields check still not 100% complete, be careful what you type in. If you got crash please report here!
          • Undo stack is more clear now
          • User manual updated
          • Other small improvement
          • clean up, reduce file sizes, typos etc...
          • small bugs, and other things what I don't remember...
            If you are interested in French UI and manual in French, don't hesitate! ๐Ÿ˜„
            Seems remember i have made the 3SKeng and site in French in the past for the fun! ๐Ÿ’š
            (seems they have updated that! There is only rest the menu on the left! ๐Ÿ˜ฎ
            For the UI I need a list or a multi-Language system, because I don't want to swim in the code! ๐Ÿ˜„
              dezmo
              Thanks a lot pilou!I am very grateful! ๐Ÿ˜„
              But unfortunately the code itself is not prepared for more than 1 language. (yet?) But at least the manual can be useful... ๐Ÿ˜‰
                French Manual! ๐Ÿ˜„
                  dezmo
                  @pilou said:
                  French Manual! ๐Ÿ˜„
                  What a nice surprise! Thanks! ๐Ÿ˜Ž ๐Ÿ˜„
                  I'll put it to the first post!
                  • FrederikF Offline
                    Frederik
                    One thing I'm really missing is the ability to make bends other than 90 degree...
                    With the 3skeng you have the option to select the bend degree when connecting it to a pipe...
                    If I select the pipe and bend, I can't get i.e. a 45 degree angle...
                    Cheers
                    Kim Frederik
                      dezmo
                      Oh, yes. Originally it is designed to make perpendicular piping between two existing point, when I did not think even of the Pipe Auto function.
                      But I get the idea of "pipe auto" and started to work on it, than pipe&bend remained as it is.
                      The drawn line endpoint is the 90ยฐbend "other end" "horizontal" projection to be able to align to the next component. Right now the pipe length is the distance between picked point minus the bend radius. I do not know what should be the length if the angle is different than 90ยฐ, because the "end" face of the bend looking somewhere other direction than the length of the pipe+bend "height" (bend "height" = the bend two end face middle point distance.)
                      If I allowing to put other than 90ยฐ I have to calculate backwards somehow and I would heve to know in advance the "height" of the bend + pipe length.
                      Did you get my explanation, because I'm already lost... ๐Ÿ˜„
                      So lot of questions raises regards your "simple" request.
                      I'll see if I can do something... Currently I don't have any idea and my boss extended my work for (in) Denmark & the holiday season is also here... ๐Ÿ˜Ž
                      • FrederikF Offline
                        Frederik
                        @dezmo said:
                        ...and my boss extended my work for (in) Denmark & the holiday season is also here... ๐Ÿ˜Ž
                        Nice to hear...
                        Too bad the weather is so bad this year...
                        Summer time can be great in Denmark, but this year we seem to have UK/Irish conditions... ๐Ÿ˜›
                        Cheers
                        Kim Frederik
                        • Z Offline
                          zxin0410
                          I am use mac os.It works fine.But i think it would be great if the font could be bigger.
                          In high resolution screen,the fonts of user interface will be too small to use.
                            dezmo
                            Thanks for feedback from MAC!! ๐Ÿ‘
                            Probably I will make a "style" with bigger font or button to change font size... or something like this, but definitely only after holiday season... sometime! โ˜€
                              dezmo
                              New version is updated to 1st and 2nd post.
                              I hope, you will like it!
                                Seems I must update the Pompi French site (this summer) ๐Ÿ˜‰
                                  dezmo
                                  ๐Ÿ˜Ž
                                  Ye, There were some changes... not that much in docu ๐Ÿ˜‰
                                  • jujuJ Offline
                                    juju
                                    why has this not been submitted to the pluginstore?
                                      dezmo
                                      There are two reason:
                                        1. It is still test phase...(but maybe good enough to submit ๐Ÿ˜‰ )
                                        1. I don't have any clue how to submit. ๐Ÿ˜• Do you have an idea and/or link about the procedure?
                                          (Actually I have a plugin in the store, but that one submitted by somebody else...)
                                      • G Online
                                        Gรกbor
                                        Rich O Brien or I can add you to the plugin author's group then you'll be able to upload your plugins to the SketchUcation pluginstore. For this to happen we need the following information:
                                        • The name you want to display as your author name in the pluginstore (it can be "dezmo" or any other name)
                                        • If you want to collect donations we need the email link of your PayPal "donate button"
                                        Please PM me these and I'll set you up.
                                          dezmo
                                          Note: The actual version can be a little different than shown below.
                                          Sorry about the quality... because the 2MB file limit
                                          You can find here the original:
                                          https://drive.google.com/file/d/1aATvf-oiEHjV9290RINv87tW6qybQTHa/view?usp=sharing
                                          Click to play!Click to play!
                                            dezmo
                                            First post updated. Some small changes in the UI, and naming of the components...
                                            and you can find it in PluginStore. ๐Ÿ˜„
                                            Download from PluginStore
                                            • 2 / 3
