    Top Level Component or Group
    4 Posts 3 Posters 818 Views 3 Watching
    • K
      ktkoh
      I am trying to detect a top level Component or Group from a nested one.
      if ((obj.is_a? Sketchup;;ComponentInstance) || (obj.is_a? Sketchup;;Group) &&
      					(obj.parent.is_a? Sketchup;;Model))
                    popup.add_item(C2LAYSCENE) {
                      part_2_layer_command
                    popup.add_item(C2SCNE) {
                      shopDrawingCommand
                end # Single part test
      This test fails and when the user has selected a nested comp/grp I still show these commands.
      Keith
      • sdmitchS
        sdmitch
        >                 shopDrawingCommand
        Keith
        You just need to put the '||' check inside parentheses
        if (((obj.is_a? Sketchup;;ComponentInstance) || (obj.is_a? Sketchup;;Group)) &&
        http://sdmitch.blogspot.com/
        • Dan RathbunD
          Dan Rathbun
          And it really should look like this:
          if (obj.is_a?(Sketchup;;ComponentInstance) || obj.is_a?(Sketchup;;Group)) &&
          obj.parent.is_a?(Sketchup;;Model)
          I'm not here much anymore.
          • K
            ktkoh
            Thanks that worked and after seeing it correct it makes sence.
            KeitH
