    Some help with msphysic helicopter model
    5 Posts 2 Posters 12.0k Views 2 Watching
    • A
      acorralejo
      Hi everyone,
      I am new in this forum, and I start playing with MSPhysic, and I don't know ´how to move the helicopter up and down or forward and reward on the air. There are no clare manuals or helps about MSPhysic, If someone can give me a hand,,, (my inglish is regular 😉 ).
      Thanks..
      I attached the lego model that I am working on.
      Base model to be uograded.. 🙂
      • F
        faust07
        Nice model. A first try. I mainly used the Thruster function. Your model is very small - not the best scale for MSPhysics. It would be better, Lego to enlarge 10 to 20 times ... 😉
        31013_Lego Creator_helicoptero_02.skp
        • A
          acorralejo
          Nice effect, now is more real, but I don't know how did you solved the problem.
          The Up vector is forcing the model up, all time o when??
          The fixed join is doing what??
          Sorry for my dudes.
          Please can you explain a bit more about the solution.
          Thanks.
          • F
            faust07
            My corrections:
            Axis correction of main components - The pivot point is equal to the position of the axis origin;
            Rotating parts defined to not collidable;
            Density of a few main groups reduced;
            Up Vector for main body "heli" with Stiffness 0.2;
            Main body "heli" Z direction directly controlled with slider "giro";
            the slider "giro" causes then simultaneously the rise and fall;
            Script off (Although I think that the experts find a better solution by script...);
            Front Lego stone controls the flight with Arrow Keys (Thruster);
            (Your script is referring to world coordinates, not on the helicopter);
            Motor Joints adjusted slightly;
            The rear rotor compensates by thruster the self rotation of the heli;
            Material Thickness and World Scale adjusted;
            Here the helicopter in 10 times magnification - easier to control.
            model 10 times enlarged
            • A
              acorralejo
              @faust07 said:
              My corrections:
              Thanks a lot for your help. I will continue whit this model and others.
              Goods comments.
              Thanks.
