    Object or No: Good Practices
    4 Posts 3 Posters 751 Views 3 Watching
    • hsmyersH Offline
      hsmyers
      Given a simple extension should it be 'objectified'? By definition, it is already an object, so is there a preference to go further? Having started before C++ but after Simula, my habit is to only sparingly use objects and then usually to make the code more straight forward. If the language is missing something and I can best model it as an object then that's what I will do, otherwise I tend to see it as overhead. Please correct or enlighten me as needed.
        slbaumgartner
        Perhaps you really mean whether to use classes or not, as in Ruby everything is an object! This question is likely to get somewhat religious answers from OO fanatics!
        You should use at least modules to isolate namespaces. In Ruby the differences between modules and classes are more subtle than in many other OO languages, but it really comes down to whether the things you are coding need to have individual memory (state) hence be instances of a class, or just shared configuration in which case you could use either.
        • hsmyersH Offline
          hsmyers
          Ah! You've detected my plan 😎 A lively discussion would be a good thing!
          Good explanation, without frou-frou. I'm familiar with C++ (very), Smalltalk (less very) and most of the script languages currently around---I'm a bit of a language slut, seldom seen one I didn't find interesting enough to learn. Because of this I am aware of OO both integral as well as bolt on, say Python versus Perl. My preference is bolt on but that's not a statement of value just something based on experience and my programming origins (IBM-BAL was my first).
          Your rationale for using an object/s agrees with my preferences particularly with short succinct code like my extension, but the discussion is young yet!
          • G Offline
            Garry K
            I've been coding all the way back to my assembler days (pre 1980). Various flavors of (Basic, Cobol, C, C++, Pascal, C#, Java), many database scripting languages such as (dBase, MSAcces, Paradox), other scripting languages such as javascript, jquery, PHP, Ruby, CSS, SQL. AWK, TCL ...
            I usually go with the flow. Borland built a very good library called the VCL (Visual Components Library), which makes use of an absolutely excellent object oriented set of classes. Easy to follow and very consistent stylisticly. This library is used by Delphi (object oriented pascal) and by C++ Builder.
            Microsoft built a terrible interface called MFC (Microsoft Foundation Classes). So when I had to use Microsoft for various early mobile devices I skipped it and used the Win API.
            With Sketchup I use a mix of both Classes (for tools) and simple reusable methods for helper functions. Even though I prefer using pointers with C, C++ etc. it just isn't possible with ruby (although under the hood most everything is passed as a reference).
            Having said all that - Ruby is quite good - although there are a few too many ways to do anything. This just means it is often a bit slower reading other code as the programmer often chooses a different way to do things.
            So I'm a bit more formal and like to use terse syntax where possible. ! instead of not, || instead of or, immediate if = ? :, parenthesis for all methods, lots of white space etc. For me it is all about readability so I can come back and speed read code I wrote months or years ago.
            But I do like some of Ruby's ways. "#{var}" the use of if after an assignment etc.
