    Module depth: Good Practices
    5 Posts 4 Posters 936 Views 4 Watching
    • hsmyersH Offline
      hsmyers
      I've a extension naming question regarding module nesting. Which is it, 1, or 2 levels? I.E.:
      Module HSMNameOfModule
      or,
      Module HSM #Author namespace
        Module NameOfModule #extension namespace
      I have foggy memories of seeing 3 deep nesting but have forgotten the details.
      • sdmitchS Offline
        sdmitch
        or,
        Option 2 is usually recommended.
        http://sdmitch.blogspot.com/
          slbaumgartner
          The first level keeps your namespace clear of anybody elses.
          The second level keeps this extension's namespace clear of your other extensions (it happens! I just had a collision between two of my extensions when I forgot about a name I had used already)
          I think a third level would be needed only in a complex suite of extensions such as Fredo6 or TomTom develop - though of course any class you define inside the second level creates a third namespace.
          • hsmyersH Offline
            hsmyers
            Useful explanation with war story 😉 The last bit reminded me where I'd seen the third level, so quite helpful!
            • G Offline
              Garry K
              I use a modified template that Dan Rathburn created. I also use his file naming convention for the loader etc.
              You could strip this down. But I like to place my plugins in a shared folder so I can test a single plugin on 6 versions of Sketchup SU7 through SU2016
              require('extensions.rb')
              module YourCompany    # Proprietary TopLevel Namespace; No Trespassing!
                module ThisPlugin   # Namespace for THIS plugin
                  # Create an entry in the Extension list that loads script called;
                  # "gkware_doormaker_loader.rb"
                  APP_VERSION = '1.0.1'
                  @plugin = SketchupExtension.new('Company Plugin Description', File.join('PluginName', 'Company_PluginName_loader'))
                  @plugin.creator = 'Your Name'
                  @plugin.copyright = '(c)2013-2016 by YourCompany'
                  @plugin.version = APP_VERSION
                  @plugin.description = 'Plugin does something - optional url to your website'
                  unless @plugin.class.method_defined?(;path)
                    # Define a singleton method for @plugin to access the @path attribute.
                    # (... because the API did not do it in extensions.rb !!)
                    def @plugin.path()
                      instance_variable_get(;@path)
                  end # unless
                  # Create local path and filename constants;
                  PATH = @plugin.path()
                  LOADER_SUFFIX = '_loader'
                  LOADER = File.basename(PATH)
                  tmp = LOADER.split('_')
                  RBSFILE = tmp[0] + '_' + tmp[1] + '.rbs'
                  # RELDIR is relative to Plugins dir, OR the dir from
                  # the $LOAD_PATH array that require used to find it.
                  RELDIR = File.dirname(PATH)
                  ROOT = $LOAD_PATH.find(false) do |abspath|
                    Kernel.test(?d, File.join(abspath, RELDIR))
                  if ROOT
                    ABSDIR = File.join(ROOT, RELDIR)
                  else
                    # assume the target dir is directly below, the dir that THIS file is in.
                    ABSDIR = File.join(File.dirname(__FILE__), RELDIR)
                  # Register this extension with the Sketchup;;ExtensionManager
                  Sketchup.register_extension(@plugin, true)
                end # module YourCompany;;ThisPlugin
