    Observer or Event when Changing Model
    5 Posts 2 Posters 732 Views 2 Watching
    • fredo6F Offline
      fredo6
      I realize that there is no way to capture the event when the user changes the current model BEFORE this happens, so that you can still do something about the current model.
      Am I correct?
      Note: there is an observer for BeforeSave, but you can change the model without saving.
      Fredo
      • Dan RathbunD Offline
        Dan Rathbun
        @fredo6 said:
        Am I correct?
        Generally yes. We have specifically asked for this observer callback. But have not yet been given it.
        You can do periodic or strategically timed tests:
        if @model != Sketchup;;active_model
          # Do something because @model is no longer active
          # but be most careful as changing non-active model
          # would likely crash SketchUp.
        or Ruby 2.0:
        module Fredo6;;Refinement;;ActiveModel
          refine Sketchup;;Model do
            def active?
              self == Sketchup;;active_model
        using Fredo6;;Refinement;;ActiveModel
        if @model.active?
          # do some stuff
        We also asked for Sketchup::Model#activate() so we can be sure that the model we wish to operate upon is activated.
        But it is not yet implemented either.
        I'm not here much anymore.
        • fredo6F Offline
          fredo6
          Dan,
          Well, thanks for the confirmation. I think that what I am looking for is a Model.deactivate observer, that is the instant where the model will be taken off current context.
          One small remark. I found that to check if the model has changed, you need to do
          model1.path == model2.path
          The reason is that I noticed in some occasion that you can have different handle for the same model. Here too, it would be good that the API has an explicit way to answer the question on whether the model was changed or not.
          Fredo
            Dan Rathbun
            This can fail. If both model's are new models, and not yet saved, the .path() returns an empty string for both, which will eval as equal ( true.)
            But that was a bug in older SketchUp versions, wasn't it ?
            I remember it happened when saving the model (most often.) But I thought it was fixed.
            I also remember some programmers testing lower level collection references instead of the model references.
            • fredo6F Offline
              fredo6
              Maybe, although I am not sure.
              But as you know, supporting older versions is also a requirement, so that, as long as the old tricks work, you finally leave it as it is.
              Fredo
