    Gothic Window
    6 Posts 5 Posters 793 Views 5 Watching
    • G Offline
      garystan
      Hi everybody :
                   This one was rendered using Twilight Render.  Comments (especially on how to improve) are welcome.      Thanks........garystan
        Gothic ? Maybe Celtic or Hobbit! πŸ˜„
        • ely862meE Offline
          ely862me
          The low segmentation of the outside arc is very bad. Also the arcs from the middle are not true tangents. And maybe you could have used roundcorner for the edges as they look to sharp for the overall look.
          Elisei (sketchupper)
          Come and See EliseiDesign
          • DanielD Offline
            Daniel
            Details. Details. Details. Unless the entire window is carved from the trunk of a redwood tree, that window would be constructed from many pieces of wood. But that isn't reflected in your model (likewise on your chair). And I see what looks like hints of reflection in glass, but where is the glass in the window? How is it attached. Some of these things you might ignore if the view was further away, but not this close if your aim is realism.
            My avatar is an anachronism.
            • G Offline
              garystan
                I wasn't sure of what "style" to call it.........Thanks.  garystan
              • Bryan KB Offline
                Not bad but it is the details that matter. For me it's the choice of wood grain and no bump mapping on any surface.
                That said, I also have some problems getting Twilight to look good, but that is probably just me not being having enough experience with it.
