    Loading skp model
    3 Posts 2 Posters 885 Views 2 Watching
      MaryamR
      hello everyone,
      did anyone ever tested the example code from the sketchup official website, The example that demonstrates how to load a SketchUp model from a .SKP file and read some data from it.
      i was testing it but the model wasn't loaded.
      SUModelRef model = SU_INVALID;
      SUResult res = SUModelCreateFromFile(&model, "test.skp");
      // It's best to always check the return code from each SU function call.
      // Only showing this check once to keep this example short.
      if (res != SU_ERROR_NONE)
      std::cout << "error " << res <<"ok";
      // return 1;
      and when i tried to display the "res" variable it showed the number 7.
      what did i did wrong ?
        You probably want to make sure you have a full path instead of a relative path. With relative it's going to look for the file in the current working directory.
          MaryamR
          yes that how i solved it full path and the number 7 that was displayed reffers to :
          SU_ERROR_SERIALIZATION if an error occurs during reading of the file
          thnx ^^
