    Create layers from list Using MS Excel & VBA
    2 Posts 2 Posters 841 Views 2 Watching
    • Miner_JeffM Offline
      Miner_Jeff
      Hello fellow Sketchup users!
      This is my first Topic Post.
      I would like to thank all the contributors on this site who have been gracious enough to share ruby code with all the users. I would not be where I am without many of the posts that are shared here. I hope to someday repay my debt to this community by perhaps sharing some of my experience and knowledge. Sketchup has really become a useful tool with all the functionality additions made possible by ruby scripting that the community has put forward for low or no cost.
      So today I am offering to the community a small program I have written in VBA to facilitate the creation of layers. I am sure there is a way to do this in ruby. However ruby code is not my strength. I can barely hack ruby code by others. I by no means am a trained programmer. It has been a long time since I was in a formal class room setting to learn a programming language. The last language I was formally introduced to was Fortran77.
      I can hack my way through VBA using help files and programs written and shared by others. My code is not meant to be as efficient as possible but it works(at least for me). I share it here for others to use or change for their own purposes. I ask only that my code is credited in future iterations.
      So what does the code do? Well I work with many layers often sequentially numbered or that follow a pattern of ascii characters and numbers. An example might be "3D-Elevation-1000", "3D-Elevation-1010" or "layer-01"-"Layer-02"... The sequence may continue to 100 layers or more. It varies from project to project. Creating the layers manually in Sketchup was too painful. Never mind the colours that Sketchup assigns. Changing the colour of many layers is very slow to do so one by one.
      TIG has been gracious enough to share with us [Plugin] Layersfromlist.rb It creates layers from a text file that has the layer name and the layer colour defined by the RGB components. Layerstolist.rb does the reverse. It creates a text file containing the layers and their currently assigned colours.
      Editing many layer colours in a row can be tedious and a slow process. This program can assist with that task and opens the door to much more.
      This excel worksheet formula will generate ramp colours where you begin with a particular colour and ramp through a number a steps (user input #steps) to another colour that is also user specified. This colour ramp delivers the transitional RGB values for use with a layer list.The layer list is imported into Excel. The transition is calculated in a straight linear fashion.
      I work and play with elevation contours and point cloud data generated from LiDAR scanning a fair bit. This tool comes in handy to transition colours by elevation gradually quickly. I also find it usefule to highlight a particular elevation layer in a snap by changing the layer of interest to something bright and reduce other elevations to less striking, say for intermediate contours for maps. You can there is no way that you can change a the selected layers colours en masse by clicking and highlighting a group then pick a new colour for the group. (It would be a nice feature though - Ruby plugin?) So a bit of the sequence... 1)Create a new layers list (column in Excel) with an accompanying list of R,G,B only changing the the colours. 2)save the list into a properly formated text file. 3)Load the new colour scheme using TIG's plugin and you have all the layers re-coloured in an instant! Don't like the colour(s)? change them again quickly with a revision in Excel and save the new scheme as a text file and reload it with the plugin.
      If ramping from one colour to another is too simple, you can build a multicolour ramp by repeating the sequence to include multiple colours with custom ramps between each as you wish. Examples could include Blue changing to green then yellow and red. You have control of the ramp rate so if you have limited number of elevations you can transition the elevation colours quickly. Totally up to the user.
      If creating your own ramps from colour to colour is not exciting enough. I have code that will allow you use to 2 websites that generate multi colour ramps based on your input. Basically copy the Hex codes from the webpage and macros I wrotewill convert the clipboard data to RGB values that you in tern copy-paste to your layer names excel sheet. See the screen grabs for instructions on how to proceed.
      http://www.perbang.dk/rgbgradient/ is one site I use. Another is http://meyerweb.com/eric/tools/color-blend/#:::hex
      (I have no affiliations with either of these sites.)
      I have attached a few screen grabs from my excel session for a visual of what I am talking about. If you are interested you can download the VBA code (as text file) and create a MS excel workbook to run the VBA macro. Also attached is the workbook (.xlsx) I used to run the excel formula (a no code). You'll have to add the code to a vba module in the excel file and save a macro enabled file (.xlsm).
      Should someone wish to have the excel file complete with the macro ready to operate, I can post that as well. Just post a request here or PM me.
      The code is in the text file.
      My code is not perfect by any means, I am not a programmer but it works for the limited testing I have done on my Windows PC. I have no intention of becoming a programmer either. 😉 Others can port the code to other programming languages if they wish. I have only used it in english on a PC. I am unable to support MAC users.
      I can offer some limited support in either english or français. Post questions here in this topic.
      I am looking for some beta test volunteers. If you wish to assist with some positive feedback about my first post or the content the I am sharing I would welcome it.
      No warranties are expressed or implied. Liability is limited to what you are paying for this software - zero dollars. (Is that the creative commons license?)
      Cheers,
      Miner_Jeff
      Simple instructions sheet1
      Website screen grab with instruction sequence.
      Various sample ramps
      A large sample ramp 62 steps
      A screen grab of the code in the text file.
      the VBA code in a txt file.
      The excel file in the screen grabs.
      • jujuJ Offline
        juju
        thanks for the contribution
