    [Plugin]SharpComp v1.0 2015-11-29
    34 Posts 14 Posters 13.0k Views 14 Watching
    • F Offline
      function
      wikki can you update combin editor. I've found it breaks dynamic components
      • W Offline
        wikii
        @rich o brien said:
        @wikii
        you should be able to update your plugins/extensions at plugins.sketchucation.com
        here you can push updates directly to the store
        I can't login http://plugins.sketchucation.com/.
        Should I use password same as http://www.sktchucation.com?
          Jim
          What functions do you need from AMS_Lib? I think this can be done without any Windows-specific functions.
          • W Offline
            wikii
            The plugin need AMS_LIB to find window which opened the component,then active it.
            • W Offline
              wikii
              v1.0 1129
              1 lock component instances when definition opened in the seperate su window.
              2 unlock component instances when the seperate su window close.
              3 rewrite codes to work more clearly.
                Jim
                @wikii said:
                v1.0 1129
                Is there any good reason that you are including Anton's AMS Lib with this? AMSLib is easily available in the Plugins Store and also the Extension Warehouse.
                You have now created a conflict - one of the libraries will re-write the other. This is not a problem until one of you makes changes which could potentially break both plugins and cause a lot of confusion for yourselves and problems for everyone else using the library.
                I hope you at least that you talked to Anton about including his work in your extension. At the very least, you need to wrap AMSLib in a different namespace to avoid conflicts.
                • W Offline
                  wikii
                  @jim said:
                  @wikii said:
                  v1.0 1129
                  In our place,many time,it very difficult to access sketchucation.com or the Extension Warehouse.
                  Thank you for your advise.
                  I remove ams_lib in the packed file.
                  • JQLJ Offline
                    JQL
                    Wikii, can I ask for a name change of this plugin in the Sketchucation Plugin Store?
                    I've literally lost hours searching for this magnificent gem, and then hours searching for this thread, and finally I found it!
                    Thanks! (and thanks for the plugin, of course, it's very good!)
                    www.casca.pt
                    Visit us on facebook!
                    • Bob JamesB Offline
                      Bob James
                      It's now called "Sharp Edit" and can be found in the Extension Store or at:
                      http://sketchucation.com/pluginstore?pauthor=wikii
                      • JQLJ Offline
                        JQL
                        Yup, I found it in SPS but it was very hard to find under that name. Probably I won't forget again, but it would be nice if it had an easier name related to component and external edition.
                        www.casca.pt
                        • JQLJ Offline
                          JQL
                          Hi Wikii,
                          I have a feature request for your consideration.
                          I've got a fair amount of components that I want to "save as" to a specific folder. Currently I have to right click in each one of them and "save as" to that folder. Is it possible to have a new tool in your plugin that does that in bulk?
                          It would be very handy, so thanks in advance!
                          www.casca.pt
                            rutpin
                            Why can't I use the plugin? I choose 'edit and save' and a new window does not open for me. I have already installed the AMS_LIB library. Please if anyone can send me a response to the email 0583224123N@GMAIL.COM
                              rutpin
                              The plugin doesn't work, even though I installed the AMS library
                                @rutpin said:
                                The plugin doesn't work...
                                Your profile says you are using SketchUp 2021 Free/Make. There is no such version, though. If you are using SketchUp 2021 Pro, it isn't terribly surprising that the plugin doesn't work. It hasn't been updated in more than 7 years. Ruby has changed at least once since then.
                                BTW, please fix your profile with the correct SketchUp version.
                                • 2 / 2
