    Pickray
    2 Posts 2 Posters 865 Views 2 Watching
      ahjkuipers
      Hello to all,
      There's something I don't understand (no, many things) and that's about pickray.
      Suppose I have a model existing of a single edge. Then I create a ray from the eye through one of the two endpoints of the on screen projection and try to find the intersection of that ray with the edge. Why is the ray (a line) missing the edge? I'm totally confused because I presumed that the result had to be the startposition (or endposition, depending of the screencoordinates) of the edge.
      An example
      def exp_a
        mod = Sketchup.active_model
        view = mod.active_view
        ents = mod.entities
        ents.clear!
        edges = ents.add_edges([0, 0, 0] , [100, 100, 100])
        edge = edges[0]
        pt = view.screen_coords(edge.start.position)
        ray = view.pickray(pt.x, pt.y)
        Geom.intersect_line_line(edge.line, ray)
      The result is nil.
      Can anybody tell me what is wrong with my assumption that in this case the result should be [0, 0, 0]? What is wrong with my understanding of pickray?
        Maybe due to precision issue?
        Not sure, but you don't have to convert between screenpoints like that:
          ents = mod.entities
          ents.clear!
          edge = edges[0]
          pt1 = edge.start.position
          pt2 = view.camera.eye
          Geom.intersect_line_line(edge.line, [pt1, pt2])
