    Clashes... any such plugin?
    16 Posts 8 Posters 1.5k Views 8 Watching
    • bazB Offline
      baz
      I just had to redraw 3 bathroom vanities because we could only get 19mm sheets instead of the 16mm we wanted.
      So I start to modify the 3 cabinets to expedite for my very accurate cutlist.
      Was thinking one hour... but four hours of cursing later...
      The thing that took the time was resolving the 'clashes'. I had front/side views set up with background line, so I could see exactly what was happening. But so many components were not lined up after my 3mm increase of thickness. And then it was very difficult to get to a view where i could 'see' & fix the problem.
      Then watching tv i saw a show on engineering where they had several 'Clashes', A term I hadn't come across before.
      "Clash:
      Refers to one building component physically yet unintentionally
      penetrating another building component; (there could be more), that is,
      components competing for the same physical space."
      Is there any way a plugin could identify groups/comps that penetrate or 'Clash'?
      And isolate them for intervention in some manner?
      Rugs
      Baz
      • JQLJ Offline
        JQL
        Building wise you can check for clashes with Trimble's Tekla Bimsight wich accepts sketchup models and is free.
        www.casca.pt
        Visit us on facebook!
        • srxS Offline
          srx
          JQL, have you tried it? Do you know how does it work in practice?
          www.saurus.rs
          • pbacotP Offline
            Also referred to as "conflicts", right? Seems based on components and groups a plugin could do it?
            • G Offline
              glro
              http://sdmitch.blogspot.fr/
              Check for over-lap of given component removes one
              http://www.susolid.com/
              same thing plus many other tools related to solids
              • JQLJ Offline
                JQL
                I did import a model into it, but I've never delved deeply into it.
                I do know what it does though...
                Insert a model of your project;
                Insert a model of your project structures or of any other of your consultant's projects.
                Check where one model interferes with the other, measure the model, produce visualizations from it and create a database with revisions.
                How far can you go with it I don't know but it's supposedly something that a Contractor or the Promoter can use to follow up on the project and construction.
                www.casca.pt
                • sdmitchS Offline
                  sdmitch
                  mod = Sketchup.active_model
                  ent = mod.active_entities
                  sel = mod.selection
                  sel.empty? ? ents=ent.to_a ; ents=sel.to_a
                  grp = ents.grep(Sketchup;;Group); sel.clear
                  for i in 0...grp.length-1
                    bounds1 = [grp[i].bounds.min.to_a,grp[i].bounds.max.to_a]
                    for j in i+1...grp.length
                      # bb=grp[i].bounds.intersect(grp[j].bounds)
                      bounds2 = [grp[j].bounds.min.to_a,grp[j].bounds.max.to_a]
                      intersectBounds = [[0,0,0],[0,0,0]]
                      validBounds = true
                      (0..2).each do |index|
                        if(bounds1[1][index] <= bounds2[1][index])
                          intersectBounds[1][index] = bounds1[1][index]
                        else
                          intersectBounds[1][index] = bounds2[1][index]
                        if(bounds1[0][index] >= bounds2[0][index])
                          intersectBounds[0][index] = bounds1[0][index]
                        else
                          intersectBounds[0][index] = bounds2[0][index]
                        if(intersectBounds[0][index] > intersectBounds[1][index])
                          validBounds = false
                      if validBounds
                        puts "#{grp[i].name} and #{grp[j].name} intersect"
                        sel.add grp[i],grp[j]
                  Checks all components for "clashes". Adds both components to the selection when overlap or contact is found.
                  http://sdmitch.blogspot.com/
                    Maybe ?
                    SU Solid by Tak2hata
                    Solid Inspector By Thomthom
                    Solid Solver by TIg
                    • bazB Offline
                      baz
                      Wow, thanks sdmitch. Now I have to figure out how to use the ruby console 😞 I usually stay well away from it.
                      • G Offline
                        glro
                        this code detects clashes of parallelepipedic volumes, when the bounding box of the object and the object, are in the same volume
                        if the objects are not parallelepipedics, you might have false positives
                          driven
                          @baz, can you post an example model, before the sheet thickness change...
                          How it's made will dictate if a 'intersect with model' can be used to make life easier...
                          john
                          • sdmitchS Offline
                            sdmitch
                            Unfortunately this is true given the way Sketchup defines bounding boxes.
                            Baz
                            To use, copy and paste into Ruby Console window and press Enter.
                              driven
                              If you have used components properly [flipped copies etc...]
                              and are prepared to pre paint faces to be adjusted...
                              a plugin can adjust the material thickness and the 'clashing' edges...
                              here's a test..
                              like this...
                              • pbacotP Offline
                                SU "knows" when faces intersect--wouldn't that be a better indicator for this analysis?
                                  driven
                                  Peter, you can use intersect to find them, but SU won't know in which direction or which faces to move...
                                  it's a bit like Solid Tools and would need many options for a semi-automated result...
                                  You would also need to manually thicken everything first...
                                  with cabinetry, it's easier if you use a material only on the items to adjust, then let ruby run using pushpull, when done you can repaint if needed...
                                  it would not be too hard to wrap my code as a plugin...
                                  john
                                  • pbacotP Offline
                                    I was thinking of the general use where you want to see if a duct is intersecting a beam. You'd just want the tool to show you where so you can fix it yourself.
