    Edges, faces, etc to layers
    3 Posts 2 Posters 545 Views 2 Watching
    • K Offline
      KrisM
      I know what I am asking for violates one of the cardinal rules of SU. I do model with all objects (edges, faces, etc) on layer 0 with groups and components on appropriately named layers.
      I also work with Revit and have the need to control visibilty of the imported SU objects. I can bring the layers from SU into Revit but cannot play with visibilty because all the actual edges and faces are on layer 0.
      Is there a plugin which will take all the objects (edges & faces) within a group or component and put those objects on the groups layer. This would only be used in a copy of the model which would be saved for the Revit export.
      Any ideas?
      KrisM
      • K Offline
        KrisM
        That works like a charm. This will save me a lot of tedious work. Thank you.
        KrisM
        • sdmitchS Offline
          sdmitch
          Any ideas?
          KrisM
          This works from the Ruby Console on a selection of components or groups.
          mod = Sketchup.active_model
          ent = mod.entities
          sel = mod.selection
          sel.each{|corg|
            ents = corg.entities if corg.class==Sketchup;;Group
            ents = corg.definition.entities if corg.class==Sketchup;;ComponentInstance
            ents.each{|e|
              if e.class==Sketchup;;Edge || e.class==Sketchup;;Face
                e.layer = corg.layer
          or this from the context menu when you right click on a component or group
          unless file_loaded?(__FILE__)
          	ent = mod.active_entities
          	sel = mod.selection
          	UI.add_context_menu_handler do |menu|
          		unless sel.empty? || (sel.first.class != Sketchup;;ComponentInstance && sel.first.class != Sketchup;;Group)
          			menu.add_separator
          			menu.add_item("Move Entities To Comp/Group Layer") {
          				corg = sel.first
          				if ents
          					ents.each{|e|
          		end#unless sel
          	end#do
          	file_loaded(__FILE__)
          end#file
          http://sdmitch.blogspot.com/
