    Code correction
    5 Posts 4 Posters 991 Views 4 Watching
    • H Offline
      hanl000
      Hello.
      I'm currently trying to create capsule shape with input parameter. I think the main work is almost done, but there are tiny mistakes I'm missing. Could you please look around and correct the codes?
      require 'sketchup.rb'
      #Creating capsule
      class capsule
         @@Radius=@@Length=@@x=@@y=@@z=@@Horizontal=@@Vertical=nil#<--class variables
         def capsule
            @@Radius = 0.mm if not @@Radius
            @@Length = 0.mm if not @@Length
            @@x = 0.mm if not @@x
            @@y = 0.mm if not @@y
            @@z = 0.mm if not @@z
            @@Horizontal = 0.0 if not @@Horizontal
            @@Vertical = 0.0 if not @@Vertical
            prompts = ["Radius", "Length", "x", "y", "z", "Horizontal angle", "Vertical angle"]
            values = [@@Radius, @@Length, @@x, @@y, @@z, @@Horizontal, @@Vertical]
            results = inputbox prompts, values, "capsule"
            if results
               @@Radius, @@Length, @@x, @@y, @@z, @@Horizontal, @@Vertical = results
               model = Sketchup.active_model
               model.start_operation "capsule"
               compdef = Sketchup.active_model.definitions.add
               ents = compdef.entities
               @Radius = @@Radius.mm
               @Length = @@Length.mm
               @Horizontal= @@Horizontal.degrees
               @Vertical= @@Vertical.degrees
           #right
           center = Geom;;Point3d.new @Length,0,0 #Length of capsule
           normal = Geom;;Vector3d.new 0,0,1
           xaxis = Geom;;Vector3d.new 1,0,0
           right_start = Math;;PI/-2
           right_end = Math;;PI/2
           edgearray = entities.add_arc center, xaxis, normal, @Radius, right_start, right_end
           edge = edgearray[0]
           arccurve = edge.curve
           verts = arccurve.vertices
           #left
           center = Geom;;Point3d.new 0,0,0
           xaxis = Geom;;Vector3d.new 0,1,0
           left_start = 0.0
           left_end = Math;;PI
           edgearray = entities.add_arc center, xaxis, normal, @Radius, left_start, left_end
           edge = edgearray[0]
           verts += arccurve.vertices
           face = entities.add_face verts
           path = entities.add_circle [@Radius,0,0], [1,0,0], @Radius
           face.followme path
           ents.erase_entities path
           group = ents.add_group ents.to_a
          pos = Geom;;Transformation.new([@@x.to_i, @@y.to_i, @@z.to_i])
          vert = Geom;;Transformation.rotation [@@x.to_i, @@y.to_i, @@z.to_i], [0, -1, 0], @Vertical
          horz = Geom;;Transformation.rotation [@@x.to_i, @@y.to_i, @@z.to_i], [0, 0, 1], @Horizontal
          group.transform! (pos)
          group.transform! (vert)
          group.transform! (horz)
          Sketchup.active_model.active_entities.add_instance(compdef, pos, vert, horz)
            model.commit_operation
            Sketchup.send_action 'selectSelectionTool;'#<--
         end#def
      end#Class
          if( not file_loaded?(__FILE__) )
            UI.add_context_menu_handler do |menu|
            dir=File.dirname(__FILE__)
               cmd_array = []
         # Create the Command object
         cmd = UI;;Command.new("capsule") {Sketchup.active_model.select_tool capsule.new.capsule}
         # Configure the Command's appearance
         cmd.small_icon = cmd.large_icon = dir+"/FGmanual/images/Capsule.png"#<--
         cmd.tooltip = "capsule"
         cmd_array.push(cmd)
             tb=UI;;Toolbar.new("Creating tools")
             cmd_array.each {|i| tb.add_item(i)}
                tb.show if tb.get_last_state == -1
          file_loaded(__FILE__)
        slbaumgartner
        Please be more explicit about what makes you think there are "tiny mistakes". I can see various flaws (e.g. a class name should start with a capital letter, also consult Dan Rathbun's frequent posts about proper usage of modules to control namespaces) but I'd rather help you with a specific problem than to write your code for you.
        • sdmitchS Offline
          sdmitch
          As pointed out by slbaumgartner, class names must be capitalized.
          Due to Sketchup's trouble with small things, I would multiply @Radius and @Length by 1000 and scale by 0.001 after the capsule is created.
          scl=Geom;;Transformation.scaling(ORIGIN,0.001)
          ents.transform_entities(scl,ents.to_a)
          edgearray = ents.add_arc and face = ents.add_face so they are inside compdef
          Since everything is in compdef, group is not needed.
          The horz and vert transformations should also use ORIGIN for the point.
          The add_instance requires a definition and a transformation. Since there are three transformations needed, they can be combined, ie
          Sketchup.active_model.active_entities.add_instance(compdef,pos*horz*vert)
          http://sdmitch.blogspot.com/
          • Dan RathbunD Offline
            Dan Rathbun
            Do NOT put spaces between method names and parameter lists:
            should be:
            group.transform!(pos)
            Read up on how to define a class, including use of the built-in initialize method, that automatically gets called by the new constructor.
            I'm not here much anymore.
            • H Offline
              hanl000
              Thank you for giving me advices. The problem has been partly fixed by myself. Maybe, I have to pay attention to studying ruby more
