    Group Copies into Components Plugin- anyone?
    3 Posts 2 Posters 544 Views 2 Watching
    • onzkiO Offline
      onzki
      Hello,
      I saw a plugin that is capable of selecting "instances" and "group copies", my question is: Is there a plugin that can I convert these "group copies" into a single component?
      I struggle in my work if a colleague (sometime me too)forgot to make one repetitive object as component (the proper way to do) and accidentally replicate that object into a huge site and no way to turn it all back to a same component except redo it again.
      Thanks! πŸ˜„
      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
      • BoxB Offline
        I think you mean Thomthoms' Groups to Components http://sketchucation.com/pluginstore?pln=tt_groups2comps
        You can select one group and use it to select all copies, then convert them to components,once they are components you can select all of them and Replace Selected from within the component browser.
        • onzkiO Offline
          onzki
          Thanks I will check it out πŸ˜„
