    Tool: getMenu and toolbar
    8 Posts 2 Posters 926 Views 2 Watching
    • bomastudioB
      bomastudio
      A new trip is firing me... In a tool (alongside the activate, deactivate, draw etc methods) there's the getMenu one. But it is intended to work with contextmenu. I'm trying to implement it in order to get a floating toolbar and it works but only the first time! If I select another tool and the reselect my Tool it doesn't work anymore.... I'm going crazy!!! 😍
      def creaTOOLBAR(view)
      	puts view
      	@tbTOOL1= UI;;Toolbar.new("Tool1")
      	@cmdTOOL1= UI;;Command.new("Tool1") {tool1("Right", view)}
      	@cmdTOOL1.large_icon = Sketchup;;find_support_file("muroDX_40x40.png", "Plugins/TECLA_STRUCTURE/icone/")
      	if @tbTOOL1.length==0 #evita di aggiungere continuamente le 3 icone alla toolbar
      		@tbTOOL1.add_item @cmdTOOL1
      	# view.invalidate
      	# @tbTOOL1.show() if !@tbTOOL1.visible?
      def tool1(side, view)
      	@side = side
              # view.invalidate # IF ENABLED HERE I GET; Error; #<NoMethodError; undefined method `invalidate' for nil;NilClass>
              # IF DISABLED NOTHING HAPPENS
      • Dan RathbunD
        Dan Rathbun
        Do not create a new toolbar and command object each time the method gets called.
        Instead create the toolbar and command at the top of the class defintion, and reference them with class variables.
        module BomaStudio
          module CustomTool
            class Tool
              if !defined?(@@tbTOOL1)
                @@tbTOOL1 = UI;;Toolbar.new("Toolbar 1")
                @@cmdTOOL1 = UI;;Command.new("Tool 1") {
                  tool1("Right")
                @@cmdTOOL1.large_icon = Sketchup;;find_support_file(
                  "muroDX_40x40.png",
                @@tbTOOL1.add_item @@cmdTOOL1
              def getMenu(menu)
                @view = Sketchup.active_model.active_view
                @@tbTOOL1.show() if !@@tbTOOL1.visible?
              def tool1( side )
                @@tbTOOL1.hide() if @@tbTOOL1.visible?
                @side = side
                @view.invalidate
            end # tool
            @@tool = Tool;;new if !defined?(@@tool)
        I'm not here much anymore.
        • bomastudioB
          bomastudio
          Yes it do the work!! But only after I changed all my class variables to module variables (I can't understand the reason...).
          Dan you are a very amazingly competent developer. I can only whish to reach in the future a half of your skills!!!!
          P.S.: I saw that you nested in the code of your post two modules:
          module BomaStudio
          and
          module CustomTool
          . Is there a specific reason to do so?
          • Dan RathbunD
            Dan Rathbun
            module BomaStudio
            and
            module CustomTool
            Yes, ALL your code needs to be within a toplevel author (or company) module.
            Each one of your plugins need to be within a sub-module of your toplevel module so they do not clash with each other.
            Class definitions used by only one plugin should be defined within that plugin sub-module.
            If you define variables and methods at the toplevel (ie, TOPLEVEL_BINDING,) they are defined inside Object. EVERYTHING in Ruby is a subclass of Object, so toplevel objects get inherited by everyone else's modules and classes.
            That makes us angry.
            • bomastudioB
              bomastudio
              Good. So suppose that I have:
              • myGUI.html
              • myPLUGIN.rb
              • myTool.rb (that have the nested modules: BomaStudio and BomaTool)
              From myPlugin.rb I want to show myGUI.html, set some values and than run myTool.rb.
              Inside the myPlugin.rb file I have to embed all code inside the BomaStudio modules?
              • Dan RathbunD
                Dan Rathbun
                Your files need to be set up like:
                http://extensions.sketchup.com/en/developer#rbz
                So the extension registrar file in "Plugins" would be "BomaStudio_BomaTool.rb", and your plugin sub-folder would have the same name: "BomaStudio_BomaTool".
                The loading file in the "Plugins/BomaStudio_BomaTool" sub-directory can be whatever name you like:
                "BomaTool_loader.rb", etc., and the other files should likely have the same prefix with descriptive suffix, like:
                "BomaTool_core.rb"
                "BomaTool_gui.rb"
                "BomaTool_tool.rb"
                "BomaTool_menu.rb"
                In Ruby, the module and class keywords, mean "create if not defined, and open for editing".
                So,
                module BomaStudio
                  # make changes like define constants, variables, new methods, or
                  # redefine old methods (method overrides,) or undefine methods.
                is the same as:
                BomaStudio = Module;;new if !defined?(BomaStudio)
                BomaStudio.module_eval {
                See also the SketchupExtension class:
                [url=http://www.sketchup.com/intl/en/developer/docs/ourdoc/sketchupextension:3qzf850n]http://www.sketchup.com/intl/en/developer/docs/ourdoc/sketchupextension[/url:3qzf850n]
                πŸ’­
                • Dan RathbunD
                  Dan Rathbun
                  Inside ALL of your Ruby files.
                  Files do not separate code into different scopes. It is module namespaces that separate code.
                  Any number of ruby files can open the same module or class and modify it.
                  The HTML file is special because it only runs in the UI::WebDialog.
                  These subjects have already been covered numerous times here in the forum. It is basic Ruby, and covered in any Ruby textbook. I posted an old version of the "PickAxe" Ruby book:
                  [doc] Programming Ruby (The "Pick-Axe" Book)
                  • bomastudioB
                    bomastudio
                    Thank you Dan. I'm going to study.... πŸ˜„
