    [Plugin] Simple Building Generator
    22 Posts 15 Posters 20.4k Views 15 Watching
    • sdmitchS Offline
      sdmitch
      @angel said:
      Can anyone help me get this extension to work. It installs Ok on SU 2013 but I don't think i understand the workflow properly as I get 'material cant be found in library' messages
      An idiots guide or run thro would help me a lot
      I have been trying this plugin and the biggest problem with it is the materials and material names. You can't use the Sketchup name or display_name. You have to paint a face in the model with any materials you want to use and then rename them and use those names.
      As for the plugin code, to make it Ruby2.0 compatible, you will need to remove the space in front of the opening parentheses,"(", on all the method call statements.
      http://sdmitch.blogspot.com/
        bboZ
        Sketchup 2019 cannot use this plugin?? pleas help me cause this plugin is so good 😞(
        • 2 / 2
