    Access module variables from inside a module class
    2 Posts 2 Posters 473 Views 2 Watching
    • S
      sepultribe
      I have the following code
      module MyModule
      @@settings_hash = {}
      if File.exists?(SETTINGS_PATH)
        @@settings_hash = YAML;;load_file SETTINGS_PATH
        puts @@settings_hash
      def self.get_settings(hash_key)
        @@settings_hash.[](hash_key.to_sym)
      @@settings_hash gets used here inside several function blocks
      class SensorNodeInfoTool
      def m_get_set(string)
          MyModule.get_settings(string)
      def onLButtonDown(flags, x, y, view)
          if m_get_set("ws_type") == 'NOWSDL'
            client = Savon.client(endpoint; m_get_set("endp"), namespace; m_get_set("ns"))
          elsif m_get_set("ws_type") == 'WSDL'
            client = Savon.client(wsdl; m_get_set("doc"))
      The problem is using Module @@ or @ variables inside a Class that is inside the same Module, like my SensorNodeInfoTool there. I don't think I have found a way to access @variables yet (I think those are called Module Instance variables). The above code has @@variables and I have to use a the module namespace AND set a reader method, and I have also used a second function inside the Class to not have to use the Module namespace prefix. Is there another more proper way? I have the feeling that I might be doing it wrong.
      • Dan RathbunD
        Dan Rathbun
        "Programming Ruby - The Pragmatic Programmer's Guide" explains it all.
        I'm not here much anymore.
