    [REQ] Reveal all Objects' nested Lines
    7 Posts 3 Posters 672 Views 3 Watching
      If not yet existing
      does it possible to reveal all lines of nested objects ?
      Here in Hidden Geometry : wanted in normal lines!
      revealed.skp
      • sdmitchS
        sdmitch
        @pilou said:
        If not yet existing
        revealed1.skp
        http://sdmitch.blogspot.com/
          Yes cool that is the result wanted ! πŸ‘
          But how have you made that ?
          (except go into manually in each component object for edit them Display/ UnMask for keep all the arborescence ?)
          (and the same for hide the Hidden geometry)
          That is not easy when you have hundreds of them! πŸ˜„
          (Maybe I miss a very easy native function)
          • sdmitchS
            sdmitch
            With a plugin that recursively goes through the model/selection and unhides the edges. In this case, it was also necessary to unhide some of the components as well.
              Ok, but where is this plugin?
              It's a new one ?
              • JQLJ
                JQL
                Tomasz has one but I think Mitch's will rock... I was tempted to see where this was going to end but here you go:
                http://sketchucation.com/pluginstore?pln=unhide_all
                sorry if I ruined something beautiful
                www.casca.pt
                Visit us on facebook!
                  @JQL : how call it ?
                  Works fine also! 😎
