    Textures in model slow down ruby?
    10 Posts 4 Posters 860 Views 4 Watching
    • W Offline
      wawmsey7
      I've written various script for drawing various parts of a cabinet, so just generally drawing shapes pushpull-ing followme etc... I'm finding that that scripts all run really nice and fast- for example one of them completes in 0.06 seconds! Which is perfect... However as soon as I bring a texture into the model, not into the script just import it into the model not even applied to anything. Then when I run the script exactly the same as before it takes 0.5 seconds to complete the same tasks!! Which is nearly 10 times as long to do the same things, the only difference being that there is a texture loaded in the materials box. The texture in this case isn't particularly large - 600kb JPEG.
      Is there anything I could be doing wrong or is there a setting to change that could help this? Or is this just how it goes??
      ('use maximum texture size' in openGL settings is set to off)
      Thanks for your help
      Matt
      ** just tried adding 3 materials to the material toolbar all with textures of about 1mb each and the same script now takes 7 seconds to complete!!! Surely this isn't just how it is??
        File size doesn't say much about the texture size when we are talking about compressed file formats. How many pixels and what's the color depth?
        Also, do you have any sample code? Sample texture? Without it's very hard to say what is going on.
        Like, are you using start_operation with the second argument (disable_ui) set to true?
        And what OS and SketchUp version are you using?
        • W Offline
          wawmsey7
          After a bit of trial and error I have found that the problem only occurs on scripts where I am pulling an external component into the model as part of the script, like this...
            shelfpin = Sketchup.active_model.definitions.load ("filename")
            ents.add_instance shelfpin, (Geom;;Transformation.new [posx,posy,posz])
          doing this works fine when no textures are loaded in the model and runs just as fast as the other scripts, however if there are textured materials in the model (as described previously) then it really slows down the script?? it doesn't slow down any other scripts...
          The components I am pulling in don't have any materials already applied...
          Anyone got any ideas? Is there a way around this??
          Thanks again
          Matt
          • W Offline
            wawmsey7
            thanks, yes I am wrapping all the code with the start and end operation commands
            @model.start_operation('Leg',true)
            ...code...
            @model.commit_operation
            I am using a new 15" macbook pro OSX yosemite with the latest sketchup pro version
            this is one of the smaller textures i am using...
            (the others exceeded the pixel limit for uploading to sketchucation (3000x2000-ish))
            • W Offline
              wawmsey7
              I've worked out that textures in the model only make the script run slowly when it is pulling/importing the component definitions into the model like so...
              and in one of my scripts I had this as part of a defined function which I was looping 50+ times to cut shelf holes and add a shelf pin for various positions on a panel - so was in affect importing the shelf pin component 50+ times completely unnecessarily.
              So as soon as I took out this out of the code completely (given that the component is already loaded in the model) and ran the same code again, it ran at the same fast speed as it does when there isn't any textures in the model!
              So my solution is to run the code to load the components needed for all my scripts once and then it's all done only once and I'm free to run any of my scripts after it.
              However it would be easier if I could have code before the code for loading the component to check if it's already loaded or not into the model and then load it if it's not already there? Is that do-able?
              **the following code just tagged on the end seemed to work fine
                 magd = Sketchup.active_model.definitions.load (file) if magd.class != Sketchup;;ComponentDefinition
              theres probably a tonne of ways to do this but that seemed to do the job
                driven
                I wondering if you still use Vray, and is it active or disabled during these 'slow' tests?
                john
                • W Offline
                  wawmsey7
                  I do use vray, but it was disabled throughout all of this... just to be on the safe side!
                    That certainly qualify for a large texture. SU will by default render textures in max 1024x1024 (double if you enable maximum texture)
                    So - I'm a little confused. You add textures by loading components containing them?
                    • W Offline
                      wawmsey7
                      No, I'm adding materials the normal way. Adding the materials isn't the problem. I was having a problem whereby adding component definitions is slower if I simply have materials with textures in the model, and the the more there are the slower it goes... but i've managed to nullify this problem by writing my code better so that I only define each component that I need to load for my scripts once.
                        Dan Rathbun
                        You need to search the DefinitionList collection properly.
                        This class, like many of the API collection classes, has the Enumerable library module mixed in.
                        The following method should be wrapped within your plugin module:
                        def self.get_component(
                          filepath = "some/path/to/component.skp"
                          # Warning, on MS Windows the definition paths are
                          # returned with backslashes not forward slashes !
                          filepath = filepath.tr("\\",'/')
                          dlist = Sketchup.active_model.definitions
                          found = dlist.find {|cdef|
                            if cdef.path.nil?
                              false
                            elsif cdef.path.tr("\\",'/') == filepath
                              true
                            else
                              false
                          return found if found
                          if File.exist?(filepath)
                            dlist.load(filepath)
                          else
                            return false
                        I'm not here much anymore.
