    Correction of codes
    4 Posts 3 Posters 537 Views 3 Watching
    • K Offline
      kmk111890
      Hello, I have a problem in making box. I would like to add box on space by adding an icon, but it didn't work well. is there anybody who can fix the code?
      ` Class Box
      def create_box1
      @lenght1 = 0.feet if not @lenght1 # along Green Y axis
      @width1 =  0.feet if not @width1  # along Red  X axis
      @height1 = 0.feet if not @height1 # along Blue Z axis
      @R = 0 if not @R
      @G = 0 if not @G
      @B = 0 if not @B
      prompts = ["Lenght", "Width", "Height", "R(0~255)", "G(0~255)", "B(0~255)"]
      values = [@lenght1, @width1, @height1, @R, @G, @B]
      results = inputbox prompts, values, "Box Red"
      return if not results
      @lenght1, @width1, @height1, @R, @G, @B = results
      model = Sketchup.active_model
      model.start_operation "Create Box"
      new_comp_def = Sketchup.active_model.definitions.add
      @pt0 = [0, 0, 0]
      @pt1 = [0, @lenght1, 0]
      @pt2 = [0, @lenght1, @height1]
      @pt3 = [0, 0, @height1]
      newface = new_comp_def.entities.add_face(@pt0, @pt1, @pt2, @pt3)
      newface.material=Sketchup::Color.new(@R, @G, @B) #color red
      newface.material.alpha = 0.4
      newface.pushpull @width1
      status=model.place_component(new_comp_def)
      Sketchup.active_model.active_entities.add_instance(new_comp_def, trans)
      model.commit_operation
      Create the Command object
      box_cmd = UI::Command.new("Box") {
      Sketchup.active_model.select_tool Box.new
      Configure the Command's appearance
      box_cmd.small_icon = box_cmd.large_icon = dir+"/box.png"
      box_cmd.tooltip = "Box"
      Create and configure the Toolbar
      box_toolbar = UI::Toolbar.new "box"
      box_toolbar.add_item box_cmd
      box_toolbar.show`
        slbaumgartner
        A few additional comments:
        You should always wrap your class code inside a module so that what you define does not go into the global namespace where it can collide with other code that used the same names by coincidence. This will probably necessitate some name scoping (using double-colon) in the code that creates the command.
        You probably don't want to invoke both model.place_component and active_entities.add_instance. The former creates a new instance and starts an interactive operation in which the user can place the instance as desired. The latter programmatically places an instance at a specified location and rotation without user interaction. Doing both is quite confusing.
        • sdmitchS Offline
          sdmitch
          Always place code in a code block.
          class Box
          	@@lenght1=@@width1=@@height1=@@R=@@G=@@B=nil#<--class variables
          	def create_box1
          		@@lenght1 = 0.feet if not @@lenght1 # along Green Y axis
          		@@width1 = 0.feet if not @@width1 # along Red X axis
          		@@height1 = 0.feet if not @@height1 # along Blue Z axis
          		@@R = 0 if not @@R
          		@@G = 0 if not @@G
          		@@B = 0 if not @@B
          		values = [@@lenght1, @@width1, @@height1, @@R, @@G, @@B]
          		if results
          			@@lenght1, @@width1, @@height1, @@R, @@G, @@B = results
          			@pt0 = [0, 0, 0]
          			@pt1 = [0, @@lenght1, 0]
          			@pt2 = [0, @@lenght1, @@height1]
          			@pt3 = [0, 0, @@height1]
          			newface.material=Sketchup;;Color.new(@@R, @@G, @@B) #color red
          			newface.pushpull @@width1
          			trans = Geom;;Transformation.new() #<---identity transformation
          		Sketchup.send_action 'selectSelectionTool;'#<--
          	end#def
          unless file_loaded?(__FILE__)
          	# Create and configure the Toolbar
          	box_toolbar = UI;;Toolbar.new "box"
          	# Create the Command object
          	box_cmd = UI;;Command.new("Box") {Sketchup.active_model.select_tool Box.new.create_box1}
          	# Configure the Command's appearance
          	box_cmd.small_icon = box_cmd.large_icon = Dir.pwd + "/box.png"#<--
          	box_toolbar.show
          	file_loaded(__FILE__)
          This code will execute but is far from a finished plugin.
          http://sdmitch.blogspot.com/
          • K Offline
            kmk111890
            Thanks, sdmitch and slbaumgartner. Now It works well πŸ˜„
            However, I'm planning to create some shapes more with this way and actually made few shapes. I'm worrying about increase of icons in Sketchup, and am making ideas how to simplify tools.
            1. Making dialog box
              I saw some free tools which 'inputbox' is added together. If the shapes can be individually selected in inputbox, I need not add icons anymore, but don't know how to make it. I know basic codes for creating inputbox, and would like to apply the basic code to what I want(choosing each shapes individually in inputbox). Additionally, Is it possible to add shapes which are saved in .skp file(I know how to load shapes saved in .skp file by using 'Class' method and how to place it on Sketchup space clicking) into inputbox too?
            2. Using webdialog
              If i create webdialog box and add all icons into the webdialog by making tables(categorization), This way may look good as well. I'm trying to use
            dlg.add_action_callback("") {|d, p|Sketchup.send_action ""}
            Can i utilize this command for making icons in webdialog? I mean, the command looked like only basic tools(Undo, Redo, New, Cut, PushPull) can be used with the command. For example
            dlg.add_action_callback("Undo") {|d, p|Sketchup.send_action "editUndo:"}
            dlg.add_action_callback("Redo") {|d, p|Sketchup.send_action "editRedo:"}
            dlg.add_action_callback("New") {|d, p|Sketchup.send_action 57600}
            dlg.add_action_callback("Open") {|d, p|Sketchup.send_action 57601}
            dlg.add_action_callback("Save") {|d, p|Sketchup.send_action 57603}
            As you know, these actions are used in HTML and '<scrip> </script>' connects between ruby codes and HTML codes for indicating icons in webdialog. How can I make my own Sketchup.send_action? If it is possible, I will add the icons into webdialog.
