    SimLab SketchUp 3D PDF Exporter
    6 Posts 4 Posters 1.6k Views 4 Watching
    • MALAISEM Offline
      MALAISE
      HI everybody
      Question: has anyone encounterred the illustrated following problem ?
      When exporting over SimLab3D Pdf, i lose all labels present in the SketchUp file
      (see attached file)
      Hints or advices welcome
      MALAISE
      Labels desappeared
        driven
        the 3dPDF is vectors and the text is rastor, so you may need to use 3dText, unless there a hybrid mode setting...
        john
        • MALAISEM Offline
          MALAISE
          Thanks John for your answer. It really helps me to understaand and find an other way. 👍
          MALAISE
            matteo
            Hello Malaise,
            I tried to test if there is a workaround.
            A label's text is a kind of "face camera" object.
            If you use the 3D Text tool, you can make a component and choose "always face camera" in the Component Window.
            Sadly Simlab can't transfer this function to a PDF. You can animate every single object, but you can't constrain it to face the camera.
            I suggest you to draw a vectorial number near every group/component of your model and add a fixed text area (with the PDF template window of Simlab) with a corresponding numbered legend.
            As alternative you can use a coloured legend, if your components are painted with an unuque colour.
            hire me: http://www.nonsolo3d.it/ !
            • MALAISEM Offline
              MALAISE
              @matteo said:
              Hello Malaise,
              Hello Matteo
              I almost have the same idea, "Numbers" and a side list. Thanks for this confirmation.
              I go further. 😛
                For no price DesignSpark Mechanichal (free VO, VF ) import export SKP, export PDF 3D! 😉
                Measure tool of the PDF is not visible! Must the Pro version of Viewer PDF necessary ?
