    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Add vertice to edge
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    5 Posts 3 Posters 8.1k Views 3 Watching
      deemn
      You can kind of do this with the knife tool by splitting the line, dragging one of the new vertices at the split, connecting with a new line segment and the dragging the vertice back so they merge, then drag the new single vertice where you want, but that's a lot of steps and you must do it for each vertice you want to add or draw a new polyline
      • sdmitchS Offline
        sdmitch
        The Add Vertex tool on my blog should do what you want.
        Usage: Plugins>SDM Tools>Edge Tool>Add Vertex
        http://sdmitch.blogspot.com/
          deemn
          in Layout? as far as I know plugins are not accessible in Layout.
          • sdmitchS Offline
            sdmitch
            Sorry but you didn't mention Layout in your post and I failed to see that the post was in the Layout forum.
            • pbacotP Offline
              From your description not sure what you want. You just, say ,have a line and want to add a vertex along it? I don't get the dragging-and-adding description. This is one of the few things that LO CAN do. Double click on line, then click on it with the option key down.
