    [Plugin] s4u Frame
    5 Posts 4 Posters 2.5k Views 4 Watching
    • hdpvH Offline
      hdpv
      s4u Frame v1.1.0
      New feature:
      Union frame in Sketchup Pro (out Group ,Component)
      s4u Frame v1.0.0
      Make frame by Component and Faces.
      http://sketchucation.com/pluginstore?pln=s4u_frame
      Suforyou
      http://www.sketchupforyou.com
      • JQLJ Offline
        JQL
        You make some really clever plugins don't you? Congratulations this one is also brilliant!
        www.casca.pt
        Visit us on facebook!
        • PixeroP Offline
          Pixero
          Great.
          A question, it seems that the "section" component is mirrored compared to the result which makes it a bit harder to edit.
          If you want to thicken the frame forward you have to edit the components back side which is a bit akward in my opinion.
          • hdpvH Offline
            hdpv
            I see .in this case,i usually reset scale then edit component.
            I had fixed it.
            Suforyou
              bsfranza
              hi there,
              i recently got the latest version on the extension warehouse.
              may i have some minor feature requests or improvement suggestions=)
              1. add option to merge only outer or inner frames
              2. add options to only merge the vertical and horizontal ones seperatly
              3. add option to fill with glass component!... here can be a lot of trickery but i think it could work
              that would be awesome πŸ˜ƒ
              great plugin - lovin it already as it is!
