    Modeling Trains - learning Sketchup
    55 Posts 16 Posters 12.1k Views 16 Watching
    • pbacotP
      Oh I missed your depot renderings of the UP desert depot. Very well done!. Good colors on the tile and all. I like the desert mountains in the background. I had expected the trains to be along a platform at the back.
      • LA_RR_ArchitectL
        LA_RR_Architect
        Hello pbacot,
        Thanks for the comments.
        Kelso is a bit of an odd depot, not really serving traditional depo functions. For example it has minimal ticketing and baggage support and no waiting room or platform. I gather that in the days before air conditioning waiting in the shade under the arcade was the best option.
        The depo served two customers: there was a dinner operated 24-7 for passengers on trains without dinning cars and recreational facilities and housing for the railway workers who ran the water / refuel stop and the helper engines that pushed trains over the hill to Los Vegas.
        I've started on the material tweaking and environment for renderings of the Point of Rocks depot, but it will be a while before I have much to post.
        • Bryan KB
          Another fine model. ๐Ÿ‘
          • LA_RR_ArchitectL
            LA_RR_Architect
            It's been a while since I posted anything, partly from my need to earn a living, partly because I needed to work out the shingles on the station and partly due to inertia.
            In any case, I've finally completed a few renderings of the Point of Rocks, Baltimore and Ohio train station in Maryland. The model is geo-located on terrain extracted from Google.
            Switch train rolling through Point of Rocks
            An overall view... working out the curving track was one of the challenges.
            Closer view from the platform
            A bit of a detail. The paving, brickwork and stone bands are textures, the slate shingles have been modeled, painfully, one at a time with the coursing and patterns as close to the photos of the actual station as possible.
            Arriving home from work late in the evening.
            ...and of course we need one of my extra dark images, imagining what it would look like arriving late at night.
            I hope you enjoy.
            Jim
            • Bryan KB
              The night shot is perfect.
              • LA_RR_ArchitectL
                LA_RR_Architect
                Good evening,
                Just finished another project, a model of a 70 ton 2 bay covered hopper.
                Basic SU model
                The model is based on a fairly schematic engineering drawing and a collection of photographs of the actual cars. This type of car carried various granulated or powdered industrial materials.
                Colored SU model
                This model of car was used by a number of railroads in the 1950s with minor variations. I picked the Norfolk Western version because I liked the inverted V cut in the side between the hoppers and like the pale gray color they used.
                3 view Max
                Hereโ€™s a three view composite from 3DMax. As you can see little additional color / texture work was needed moving it into Max, mostly adding more realistic metal surfaces.
                Max detail vies
                I really like hoppers because I can expose a fair amount of detail in the open ends. In this view in addition to a lot of piping, you can see the reserve air tank and below that the brake valve mechanism.
                On the other side of the car, you can see brake cylinder and the levers used to actuate the brakes.
                Hereโ€™s the 70 ton hopper coupled into my switch train.
                And finally, the switch train crossing the Gloucester River draw bridge on a sunny summer afternoon.
                As usual, I had a lot of fun building this little car.
                Jim
                • pbacotP
                  IMG_0086.jpgI made it to the Kelso Depot last year. Your images are totally right on with the original. Nice work!
                  • LA_RR_ArchitectL
                    LA_RR_Architect
                    Way out in the middle of nowhere isn't it? The building is well preserved and makes for an interesting visit if you're passing through.
                    In doing the model I worked from some really nice drawings and photographs from the Historic American Buildings Survey that I downloaded from the Library of Congress. They show it before it was fully restored. In doing my model I tried to scrub out changes made to convert it to a modern visitor center.
                    I also visited the building (a day's drive from home) to photograph it and the surrounding landscape but you got better sky images. It was cloudless blue when I was there.
                    Thanks for the feedback.
                    Jim
                    • Bryan KB
                      Top notch models as always!
                      • Lostboy30AL
                        Lostboy30A
                        Hi, has anyone used Sketch Up (SU) to design open frame scenic railway boards made of shaped ply? I was at my model railway club in London, UK, and another member recommended SU as I was inspired by this efforts on this N (UK 1:148) layout below.
                        I think mostly I will be taking a lot of time to look at the basics tutorials to get myself out of some jams I'm in. This might be considered the easiest 3D app to use, but it seems like the trickiest new app I've tried so progress is slow.
                        https://www.youtube.com/watch?v=iVyPN2QyIjI
                        • Bryan KB
                          There are a lot of tutorials here* and on YouTube, but they are scattered around. SketchUp should be perfect for what you want to do.
                          The best thing is just keep at it and it will all make sense eventually. 3D is hard to begin with, but SketchUp is by far the easiest to learn. (to which I first said "This is easy?!") ๐Ÿ˜„
                          Also consider plug ins. There are a huge number of plug-ins that make modeling easier.
                          • https://sketchucation.com/forums/viewforum.php?f=18 <- click here for SketchUcation tutorials
                          • LA_RR_ArchitectL
                            LA_RR_Architect
                            In any case, i think you've made a good decision. Sketchup is an easy, although not foolproof, system and can do remarkable modeling. It's definitely the easiest system I've used.
                            It is easier to do rectangular shapes but at least initially the plywood components of your model should be pretty near 2d and fairly straightforward. Arcs and circles are not bad as well.
                            If you're working with modular track elements things should also be pretty simple. Once you get to spline curves (i.e. flex track,) and topography things get a bit trickier.
                            I recommend showing us your progress, perhaps opening a thread devoted to your progress and problems. I'm sure you'll get a lot of good advice.
                            Jim
                            • LA_RR_ArchitectL
                              LA_RR_Architect
                              This week I was able to take a break from work and crank out another piece of RR rolling stock. This time a "heavy weight" PRR dining car.
                              For a slab sided fairly basic shape it proved to be more technical and challenging that I had expected. The roof ends were especially fun.
                              this is the model without color or transparency
                              ...and here pre-colored for the render sytem
                              With colors and textures representing a freshly shopped and cleaned car
                              A detail
                              Assigned to a train rolling into Florin PA
                              I hope you will enjoy but questions, observations and criticism are always welcome.
                              • tuna1957T
                                tuna1957
                                your train car and station models are epic ( the renders are fab too ). love it when you post new stuff. ๐Ÿ‘ ๐Ÿ‘
                                • pbacotP
                                  That's a beautiful dining car! Enjoy studying the models and renders. Better than photos in a way!
                                  • 3 / 3
