    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    DesignSparkMechanical Vx
    13 Posts 3 Posters 14.0k Views 3 Watching
      A last find some times for test it! ๐Ÿ˜„
      Works very fine! DesignSpark has a new version 2 !
      Very similar than SpaceClaim ! ๐Ÿ˜‰
      Can export in OBJ, STL, and...SKP โ˜€
      For Nurbs in Moi3D Thx to Max Smirnov! โ˜€
      http://s6.postimg.org/sorv92tsh/claim2.jpg
      http://s6.postimg.org/u2ji4dt1t/claim2moi.jpg
      Sketchup on Steroรฏds! ๐Ÿ˜„
        Any other trick for simulate the Sketchup PushPull after a fillet ?
        here a duplicate face! ๐Ÿ˜„
        Funny thing Design Spark can import SKP file from V3 to 2014! ๐Ÿ˜„
        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/4413661_orig.gif
          I have found! ๐Ÿ˜„
          But not sure that will work more speedy than my first "duplicate"! ๐Ÿ˜„
          You must select strictly 3 edges!!! (1, 2, 4 don't work)
          (of course in SU it's trivial ๐Ÿ˜„
          http://s6.postimg.org/k9bmho769/pushok.gif
          • JQLJ Offline
            JQL
            Seems very good. What you imagine can be done with it? I will test it eventually... but
            www.casca.pt
            Visit us on facebook!
              It's "direct modeling" (more than Sketchup) for mechanical modeling
              but accept SKetchup file Export Import! ๐Ÿ˜„ 2014
              (whithout textures ! Allows set colors for the different colors / textures from SU )
              And perfect for something like complex Shells (molding) or Fillets for example!
              As free it's a true gem! ๐Ÿ˜„
              By Odrik
              http://i55.servimg.com/u/f55/16/30/24/60/captur16.jpg
              here the top (gutter) was modified and re-export to SKetchup
              http://i55.servimg.com/u/f55/16/30/24/60/captur15.jpg
              Gutter created by Shell
              http://i55.servimg.com/u/f55/16/30/24/60/captur19.jpg
              Post adaptation
              http://i55.servimg.com/u/f55/16/30/24/60/captur21.jpg
                PS;) thx Burr
                Select Edge then Face + Ctrl ๐Ÿ˜„
                http://s6.postimg.org/ld0c7dh75/pusho.gif
                  Happy Easter! ๐Ÿ˜Ž
                  DesignSpark permits to make PDF 3D !!! ๐Ÿ˜„
                  And allows with a little trick to input Nurbs like STEP format from any progs like Moi for example! ๐Ÿ˜„
                  A little trick for the "Only read file STEP imported"! ๐Ÿค“
                  Import the STEP file
                  Add a solid to the drawing (cube, cylinder, sphere, whatever).
                  Right click on the top-most name of the component tree (the name of the whole thing).
                  Unlock. Everything in the tree is now unlocked.
                  Have fun modeling! โ˜€
                  If you want the PDF 3D File, it's here! ๐Ÿ’š
                    some tricks ๐Ÿ˜‰ more on my site ๐Ÿ˜„
                    For reduce or increase a surface
                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/5682330_orig.gif
                    For make a rotation an object must be previous point axe existing :gride is not sufficient!
                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9026747_orig.gif
                    Measures frame can be hide by click on it for have properties!
                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/7796022_orig.gif
                      Very exotic method for see the volume of an object! ๐Ÿ˜„
                      You must have 2 volums minimum
                      And for see the last of a serial you must copy it!!! ๐Ÿ˜ฎ
                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1421979_orig.gif
                        A trick for have objects from DesignSpark Mechanical in nurbs format inside any Nurbs program! ๐Ÿ˜‰
                        Use Fusion 360 : it has format SAB !
                        As the format Rsdoc from DesignSpark Mechanical can give directly SAB format!
                        (rename myobject.rsdoc in myobject.zip, unzip it you have the file .SAB inside the folder SpaceClaim/geometry ! ๐Ÿค“
                        Fusion 360 who is Free for students, enthusiasts, hobbyists, and startups
                        Full use of Fusion 360 Ultimate for as long as you need it!
                        ๐Ÿ˜„
                          jpalm32
                          I use Design Spark PCB mostly for Electronic design. Played with this a little. Seems very good for mechanical type stuff...enclosures, metal work....
                            Always alive! ๐Ÿ˜‰ Always free
                            hhttps://www.youtube.com/watch?v=9wDUiWpmfLs
                              Tested 5.0 works fine : import export SKP (geometry)
                              For Nurbs : Import Step export SAT (with tricky tinker above but working fine) ๐Ÿค“
                              And can generate a PDF 3D! ๐Ÿ˜„
                              https://images2.imgbox.com/e8/b9/Jhux4JJb_o.gif
